Turn cd player on and it immediately says f61 and turns itself off?
    Brigadier General:
  • 8,546 Answers
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 20, 2011
It is showing F61. Manual says a speaker wire is the problem, but can't seem to find the wire that is the problem.
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Mar 07, 2011 | Panasonic SCAK410 5-Disc CD Changer
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Oct 04, 2010 | Panasonic SC-AK600 CD Shelf System
Every time i turn the stareo on it shows f61 then it turns off
your panasonic is in service mode, only pansonic service center can fix that problem..
Jun 18, 2010 | Panasonic SCAK410 5-Disc CD Changer
What does error f61 mean unit switches itself off immediately
Depending on the model, it could mean power amp problem or power supply problem.
Dec 03, 2009 | Panasonic Audio Players & Recorders
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
Error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
May 31, 2009 | Panasonic Audio Players & Recorders
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
43 people viewed this question
 Grubhead
Grubhead
