Question about Casio FX82MS Scientific Calculator
I use a Casio fx-82MS, how do I reset it? When I press 0.5/500 I get an answer with exponents.
  • 7993 Answers
SOURCE: sin, cos, or tan, on casio wrong answer. another cac right answer
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Posted on Sep 17, 2009
  • 7993 Answers
SOURCE: how do i calculate permutation in fx-82ms casio
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Posted on Sep 06, 2009
  • 7993 Answers
SOURCE: PLEASE HOW DO I CHANGE MY CASIO FX-82MS
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below. Hope it helps.
Posted on Oct 11, 2009
  • 7993 Answers
SOURCE: i am a casio fx-82MS user. i would like to know
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Posted on Nov 16, 2010
SOURCE: Reset?!
thnx
Posted on Mar 02, 2008
Could you please help me .. Is it possible to calculare irr with casio fx 82 ms? Thank you very much
Internal Rate of Return (IRR) Calculation Using Casio MS ...
? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
Discounting Basics on Casio fx-991ES and fx-82MS ...
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
Jan 10, 2016 | Casio FX82MS Scientific Calculator
How can I reset my casio calculator fx-82ms
There should be a small reset hole! Press this in with a paper clip or similar for about 10seconds
Oct 17, 2014 | Casio FX-82MS Scientific Calculator
Changing rad to degrees mode on fx82mu
fx-82MU?
If you mean fx-82AU, press SHIFT [SETUP] then 3, 4, or 5 to select the desired angular mode.
If you mean fx-82MS, press MODE then 1, 2, or 3 to select the desired angular mode.
Casio calculators almost always have the angular mode in either the MODE or SETUP menus.
Jul 23, 2014 | Casio Office Equipment & Supplies
How do i calculate the normal probability value, give z-value, on casio fx-82ms
The fx-82MS does not have any built-in functions for calculating the normal probability distribution or its related values. You can calculate it using the defining function or any of a large number of approximations. Alternatively you can look up the values in a table.
Some advanced calculators have the functions built in, and programmable calculators can be programmed to give them. Sadly the fx-82MS is neither.
For more about the normal distribution, see http://en.wikipedia.org/wiki/Normal_distribution
Jan 21, 2014 | Casio FX-82MS Scientific Calculator
Casio fx-82ms calculator does not give me an answer when i use the percentage button . example if i type 0.25/ 100% i get 0.25 instead of the right answer 25
Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages.
To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign.
To convert from percents to decimals, move the decimal mark 2 places to the left.
Sep 28, 2013 | Casio FX-82MS Scientific Calculator
My casio fx 300 answers questions in exponents instead of decimals, how do i reset this?
Press SHIFT [MODE] then select one of either the "Fix" or "Norm" modes. See page E-8 of this manual.
Feb 10, 2013 | HP Casio FX-300 Plus Scientific Calculator...
How do I enter pi on Casio fx-82MS
Press and release the SHIFT key at the upper-left corner of the keyboard, then press and release the EXP key at the center of the bottom row.
Note that the EXP key has the Greek letter pi printed above it in yellow.
Jan 24, 2013 | Casio FX-82MS Scientific Calculator
HOW TO SET FX-82ms TO RADIANS
Press the MODE key until you get the "Deg Rad Gra" screen. Press 2 to select radians.
May 19, 2012 | Casio FX-82MS Scientific Calculator
How to set casio fx-82ms scientific calculator to radians
Doubts
how to calculate antilog in fx-82MS
Nov 18, 2008 | Casio FX-300MS Calculator
Casio FX82MS Scientific Calculator Logo
3,517 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
