Question about Cycling
Rear dura ace brake pad rubbing on left rim - Cycling
    Brigadier General:
  • 8,546 Answers
Adjust it or true the wheel or mount the wheel correctly in the frame/fork.
http://www.parktool.com/blog/repair-help/sidepull-brake-service
Posted on May 20, 2011
REAR BRAKES SQUEAL
I believe it is due to the paint on the rim. I used rubbing alcohol to clean both sides of the rim where the brake pad makes contact and it stopped the squeaking.
Feb 21, 2014 | Kent 26" Del Rio Womens Cruiser Bike,...
1997 Honda VT 1100 C Shadow Ace new rear brakes squeal
Hi, Anonymous brake squeak is usually caused by excessive heat build-up that produces a micro-thin shiny glazed film on the brake pads and brake disc rotor that is harder than chicken lips and everyone knows chicken lips are harder than diamonds. Basically, the leading edge of the brake pads acts like the needle on a record player and the brake disc rotor as the record producing the infamous "SQUEAK MUSIC". You may have a pad in which the material was not blended evenly and you are encountering hard spots that are causing the squeak. Another possibility is that the pads are equipped with a wear sensor. This is a small metal tab attached to the pad that rubs on the rotor when the pad is worn to the minimum usable thickness The glaze can easily be removed by sanding the pads in a circular motion on a flat piece of metal, glass or concrete covered by a medium grit sandpaper until the shine is gone and raw brake pad material is visible. The brake disc rotor needs to be deglazed with a power tool, air or electric, that has a 2" sanding pad of Scotch Brite or medium to fine grit sandpaper until the shine is gone. Chamfering the leading and trailing edge of the brake pads at a 45-degree angle will act like a dull needle prolonging or totally eliminating the return Mr. Squeak.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
rear brake squealing
rear brake squeel noise Discussion
Honda SHADOW VT1100 Owners Workshop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Jun 25, 2012 | 1997 Honda VT 1100 C Shadow Spirit
Hi, I have a toyota corolla 2003 that's making a metallic sound in the driver's side rear when turning right in reverse
Check your brake pads and or brake rotors. They may be bad or your rim on is rubbing on the shock absorber. Also check the lug nut's on your rims they could be loose to where the tire is rubbing against the brake rotors or shock absorber.
Good Luck!
Feb 08, 2010 | 2003 Toyota Corolla
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
Worn out rear brake pad only on 1 side...
sounds like the caliper is defective, replace rebuilt the brake caliper.
Jun 03, 2009 | 2003 Honda Element
Shimano Dura Ace Brake lever chatter
A few suggestions:
Lube/replace your cables and housings. If your housings are getting rusty on the inside, it will prevent the tension in the spring of the calipers from returning the brake levers to "home" position. Also, dura-ace levers have an internal return spring that is prone to breaking or coming off its peg (this can't be repaired without disassembling the lever).
Make sure your calipers are clean and move freely, and have sufficient spring tension to return to "home" position.
Be careful not to get lubricant on the braking surfaces, obviously.
As an experiment, remove the wheel and pinch the calipers together with your hands. Then, check to see how loose the brake lever is.
Mar 26, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
80 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
