Question about Fisher and Paykel Washing Machines
My fisher paykel top loader won't do a cold wash.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
Posted on May 21, 2011
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My top loader washing machine is not getting enough water-trickling only on cold water (hot is ok).
The inlet valve has failed & needs to be replaced unless you don't use hot water then you could just swap the hoses over.
Feb 18, 2011 | Fisher and Paykel IWL12 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel eco smart washer top loader
If you talk with the company, they'll explain that their machines are designed to clean clothes in cold and warm water and that, in most instances, they don't feel "hot" water is at all necessary; especially if you use the soak cycle. You have to remember that the company is all about eco solutions and energy efficiency. They included the 'no hot water setting' work around just to as a customer accommodation. I haven't found that it takes all that much pressure, you just need to keep them depressed long enough for the unit to get the message and signal that it has.
Jan 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
145 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
