Question about AEG 23 in. Favorit 86070Vi Built-In Dishwasher
My aeg disherwasher will not switch on - no power. Have you any ideas what might be the problem. Many thanks. L. Wilson
  • 63 Answers
Check breaker panel, check door switch/latch
Posted on May 20, 2011
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Jul 25, 2012 | AEG Washing Machines
Hello i am repair man . i have a washing machine model aeg 76800 machine take a program correctly and start but after 5 second stop it please help me quicly thank you
when it stops do you still have power to the front panel if there is no power to the panel then you would have a bad connection to one of the control boards. are there any error codes showing when the unit does stop such as flashing lights or an exact er code have you checked the door switch? if the door switch does not work the unit will start then stop immediatley message me back with your finds thanks Rick
Apr 24, 2011 | AEG L76800 Front Load Washer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Setting SWR
hi ken, SWR has nothing to do with your power supply, Standing wave ratio, It is the amount of power which is reflected back to the radio when transmitting, If you have a SWR of 10 or over on a wilson 5000 I would imagine you have a short in your feed line[coax].
I would replace the pl259 connector and check the coax for damage.
Paul,.
Sep 21, 2009 | Wilson Electronics Cellular Magnet Mount...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing.
This has happened before - design error with AEG
May 27, 2007 | AEG Lavamat 88840 Front Load Washer
AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
598 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
