Question about Panasonic DMR-EZ48 DVD Recorder
When i finalize a dvd on the recorder, it plays back on the recorder it was finalized on but not on other dvd players. This just started happening, It worked ok before
  • Panasonic Master
  • 508 Answers
It can depend on many things, including: the format of DVD that was 'finalised' (for example, if you tried to finalise a DVD-RW in this unit, it will playback fine in it, but not in a normal player). Let us assume that you used a DVD-R, which is meant to be recorded once then finalised for compatible playback in all players. If that is the case, your DVD recorder might have a software issue which can only be checked by a qualified technician in a fully equipped service centre. You cannot fix this yourself, and I do not recommend online firmware updates, in case you get what looks like the right version for your model, but ends up being completely different and damages your machine permanently. You may also have a faulty digital controller board (the little board the DVD-RAM drive connects directly to) - if so, this may need to be replaced as one part; since it is not fixable at component level.
Get a quote from an authorised Panasonic repair workshop before going any further (this unit is repairable/fixable; just not at consumer/owner level). The quote will not only tell you what exactly is the issue, and what needs to be done, but also the likely costs involved to correct it.
Assuming you used the correct DVD formats for recording/finalising, and the problem persists regardless, the workshop could be your next option. Only pursue this if you want the unit restored to full operational condition and you are prepared to accept the expense, unless you have some sort of warranty.
Posted on May 20, 2011
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Vcr/dvd when can i finalize my disc iam recording i have a magnavox combo before i starte or after tapeing
Finalizing means that you're finished and you won't be putting anything else on the disc. Finalize it after you're done so it will play on other DVD players. If you have a rewriteable DVD, then you can go back and erase it and record over it later even though you've finalized it. If you have a -R or +R only, then you can't and whatever is on it when you finalize it will be on it forever..
Dec 08, 2009 | Philips Magnavox DVD/VCR Dual Player
Recording (toshiba dvr player se-r0265
Number SE-R0265 is not a Player. It is the model number of the Remote Control for a player.
However, your question is somewhat generic for all Player/Recorders. First you must use good original manufactures DVD media for recording. TY (Taiyo Yuden) is the Toshiba recommended media in many of its manuals. Verbatim and Fuji are also very good. They are more expensive, but very much worth the extra cost in reliability and headaches. Also, some older recorders will have trouble recording/playing back/finalizing newer 8X or 16X faster media. Try to by 4X and slower media if you are having problems, even with the three recommended above.
Second, DVD-R or R/W media has to be 'Finalized' before it can play on other recorders. DVD media do not. Try using DVD media if you continue to have trouble. Also, there are two recording/format types you can choose to record with on your DVDR Recorder, Video and VR, on -R/W media. Video is automatic Video format only on DVD media and do not need to be formatted (I think) before use or finalized after done recording.
If you are still having trouble using -R/W DVDs on other players, Try DVD DVDs in Video Format.
Finally, Toshiba is know for DVD media sensitivity. Many of their recorders have Firmware upgrades. Be sure you have the latest by looking in your manual to find your Firmware Version, then check out Toshiba's support site for any upgrades. But, start with good media, finalizing -R/W media, using Video disc format, then using DVD media, in this order.
Apr 03, 2009 | Televison & Video
Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
Jun 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Dvd finalization
I turned off the Colby recorder then turned it back on and inserted the DVD and chose the edit button on the remote controller. The correct menu with the close and finalize choice became available.
May 26, 2008 | Coby DVDR1280 DVD Recorder/HDD Recorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Panasonic DMR-EZ48 DVD Recorder Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
