Question about Car Audio & Video
I have a audi ab 2003 2.7 turbo and i had to change the transmission module and now the raodio is in safe mode. i bought the car from someone else and there is no manual in it so what do i do.
  • 345 Answers
SOURCE: 1997 Audi A4 B5 fuel pump
what makes you think its the fuel pump.......explain your problems (codes if you have any)and i might be able to help you......please give a good description of your fault please
Posted on Nov 11, 2008
SOURCE: Need Help A.S.A.P Please!!! 2002 Audi A6- CVT transmission
Did you know that you are not suppose to warm up a Audi ???? Refer to your MAnual
Posted on May 06, 2009
SOURCE: My Audi A3 2.0 tdi limp mode/turbo overboost
i also have done a diagnostic test and it states a turbo overboost condition and it drives fine locally but loses power on the motorway and struggles to reach 80mph? any suggestions please email me at shiz86@hotmail.co.uk
Posted on Sep 14, 2009
TDISLine
  • 1874 Answers
SOURCE: how do i get the audi radio off safe mode?
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Please rate my response. Thanks!
Posted on Apr 30, 2010
SOURCE: Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
Posted on May 16, 2010
Where is the transmission control module located on 2005 Mazda 6
Safe mode limits engine performance, and does not effect transmission, especially not by eliminating first and second.
The main way to get out of safe mode, is to remove the battery long enough for the whole system to discharge and reinitialize, so by changing the battery, you likely already did this.
More likely is why the battery died? If you have a wire rubbed through, that could be shorting everything? Have you done a voltage output check on charging system? But other than linkage switches, the transmission control module is inside the trans oil pan, where all the solenoids are. You can drop the pan to ensure all the connections are solid and jump the solenoids to ensure they are not burned out.
Jan 10, 2016 | 2005 Mazda 6 i
AUDI A3 OVERBOOST 20. TDI 04 SAFE MODE ISSUE
Code P0234 Check N75 boost control solenoid and all vacuum hoses to and from N75.
If performance returns after brief ignition key cycling, Off /On.....check for vacuum to turbo dump valve canister.
If performance is always low, check turbo vanes for sticking or 'snow screen' in snorkel to air filer is not restricted..
Oct 30, 2013 | 2005 Audi A3
My audi TT jerks when decelerating?
I'm finding that you can buy Audi TT turbo charger kits if you'd like for your Audi TT to be turbo charged. -----------------------------------------------------------------------
Renault car key
Apr 16, 2013 | Audi Cars & Trucks
Transmission problem.what causes an a4 audi to hesitate to pull off on an incline??
one of two things...cheapest is to change your transmission fluid and filter first. or your pick up modulator is going bad.
Apr 13, 2013 | 2003 Audi A4
My Audi jilts when accelerating
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 09, 2012 | Audi Quattro Cars & Trucks
2002 audi a6 transmission is in safe mode. What
hi, what it usually mean is that you have shifted down in to a lower gear whilst the revs where to high so then your gearbox goes into safe mode to protect it from further damage the only way to reset this is to take the car to a main dealers and have a diagnostic check done.
Let me know how you get on or if you need further assistance ok
Feb 13, 2010 | 2001 Audi A6
2003 Audi A6 ESP and ABS Lights Activate
I am having the exact same problem. The new sensor under the rear seat did not solve the issue. Does anyone have a solution?
Sep 15, 2009 | 2003 Audi A6
Audi Flashing gear display
The vehicle would seem to lose power as the transmission has gone into 'safe mode' and the transmission control module has detected a fault in the transmission hence the flashing gear display. you need to get someone in a dealer or someone that has the technology to plug into the car and find out what the problem in the trans is. hope this helps.
Aug 04, 2009 | 2005 Audi A4
Sep 18, 2008 | 2000 Audi A6
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
