Question about HP DESIGNJET T770 Printer
Hp Designjet T770 Printer is always stopping at the ink station when starting up with error 22.0.10 I ve tried to remove and replace the ink cartridges and printer heads but nothing has changed Sometimes it has started normally but failed to proceed with printing by stopping at error 22.0.10 I ve tried the technique of keeping the power up button pressed down as I switch the printer on and it worked once and resumed to stopping with error 22.0.10 I tried removing the power supply plug from the socket while printer was on, replugged and and switched on again and there was no change
    Habit-Forming:
    New Friend:
  • 85 Answers
You might need to reset your network settings.
Get instant recommendations for free here - http://bit.ly/geekkfrmc
Posted on Apr 18, 2017
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
michael464
  • 8 Answers
SOURCE: Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Posted on Dec 31, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 144 Answers
SOURCE: HP C6180 Incessant Switching On and Off
The best way to deal with this issue is making sure that the printer isn't plugged to a surge protector
and performing a partial reset
you can achieve this by unplugging the power cable and pressing # and 3 and then replugging the cable and hold the # and 3 buttons until you see the lcd lit up
also try the # and 6 and then # and 9 to reset it to factory defaults if the previous doesnt work
Posted on Jul 14, 2009
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
Jan 02, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
21.2:13 error code HPT770
21:2.13 error- service station fail- these can be ordered but need fitting by an approved engineer
part number CH538-67040
Dec 30, 2013 | HP DESIGNJET T770 Printer
Type your probl 22.0:10 Restart the printer. If the problem persists, call HP Support
Left ink supply station needs replacing.
Call a tech to look at it.
Nov 02, 2011 | HP DESIGNJET T770 Printer
21:13 error code in t770
There is a problem with the "service station".
You are going to need a tech to look at it.
Oct 01, 2011 | HP DESIGNJET T770 Printer
How to find star wheel motor in hp designjet T770 hdd printer
Are you tech guy?..If not don't try to open it..its is not so easy..Remove left coverRemove main PCARemove Spit onThere you can see the star wheel unit..
Sep 14, 2011 | HP DESIGNJET T770 Printer
I'm getting 47:01 error on a DesignJet T770, read something about cleaning a star wheel...What is it and where is it located?
It doesn't need cleaning, it needs to be replaced. It's located on the right side of the printer behind the ride side cover. If you haven't been trained you arn't going to replace the motor. After it gets replaced the printer has to be re-calibrated. If it is still under warranty, use it. Otherwise, get a designjet tech to work on it.
Aug 24, 2011 | HP DESIGNJET T770 Printer
Hp design jet T770 plotter display 21.2:13 on the control panel
Tech guys only:
Service station error..Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel) best of luck...
Jul 12, 2011 | HP Designjet T1100ps Printer
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Just got a new HP Designjet T770 hard disk printer, keep getting error code 21.1:03, turned power off and unplugged, still receiving same error code
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
May 24, 2011 | HP Designjet T610 InkJet Printer
Hp 770 have an error ------21:13--- Please help me
21 error indicates a problem with the service station. You need to make sure that there is nothing stopping the proper movement of the service station such as a piece of paper. If you do not find anything there, shut the machine off completely and then restart. If the error returns, you will need to run the service station diagnostics, I do not have the procedure in front of me right now but if the error persists, post back a comment and I look it up for you.
May 19, 2011 | HP DESIGNJET T770 Printer
HP DESIGNJET T770 Printer Logo
2,136 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
