Question about GE PTC22MFM Top Freezer Refrigerator
PTC22MFM makes noise all day and there's water leakage in bottom fridge area. defrost all day, noise still there after a restart.
  • 63 Answers
Check the fan in the freezer and the fan for the condenser (behind unit in the bottom and clean the ciol for the condenser under unit
Posted on May 20, 2011
Leaking water on floor
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 08, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom Freezer: Ice is collecting on the bottom of the freezer which I need to scrape out every 5-7 days or I wind up with water on my kitchen floor. What could be the problem?
Feb 23, 2015 | Refrigerators
Every couple of days i wake up to a little pool of water that is leaking from my refrigerator. Any advise?
Jul 05, 2014 | Kenmore Refrigerators
Whirlpool fridge model wro34uw leakage help please. I've noticed that most people that have posted have water hooked up and ice/water dispensers - my fridge doesn't have these features, just a...
At the back of the fridge check for a small drain hole that allows the water to flow out to the top of the compressor They do block up from ice and food residue (peas -milk etc) I would have a very serious talk to the rental agency as the fridge repair is the responsibility of the land lord as it came with the property. Ask for a new fridge or a good serviceable fridge. The freezer door gaskets are probably not sealing ( gone hard) allowing air in with the air moisture turning to ice.
Jun 25, 2013 | Refrigerators
Heaps of frost/ice in freezer: Whirlpool wro34uw
You probably need to fully defrost the freezer. Switch it off for at least 24 hours and collect the water as it defrosts. Do not try to scrape it as it can damage the product. The cracking and poping noises are most likely the product trying to auto defrost. It is probably too iced up for Auto defrost to work which is why you need to fully defrost. Good luck.
Feb 20, 2012 | Refrigerators
My fridge is making a loud noise that sounds like an air compressor.
The defrost is not working and ice has built up and is hitting the fan...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 20, 2010 | GE PTC22MFM Top Freezer Refrigerator
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leakage
It is possible that your refrigerator is not defrosting properly. If it has a timer defrost try to turn it slowly clockwise until you hear a click and about one minute you should hear a crackling noise indicating the freezer is in defrost. If the timer does not turn and defrost about every 8 hours I suggest you change the defrost timer. Let me Know, Thanks, Sea Breeze
Feb 26, 2009 | Kenmore Refrigerators
Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Jan 27, 2009 | KitchenAid KSRD25FK Side by Side...
Water dripping from freezer to fridge
Sounds like the drain for the defrost cycle water may be plugged and you eventually overflow water. See if you can find the little drain hole for the coil defrost water and check for dirty/plugged. Try to pour hot water in the drain area and see if it runs out the drain fast (if real slow it's a problem). Make sure the water is also going down to the holding pan near the bottom area/compressor area (that's where it evaporates later). Let me know what you find.
Nov 28, 2006 | Kenmore 63782 / 63784 Top Freezer...
GE PTC22MFM Top Freezer Refrigerator Logo
121 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
