Panasonic CS-A28BKP5 with CU-A28BKP5 fan works but will not heat or cool no leaks detected
SOURCE: Panasonic AC Model CS-A28BKP5 remote not working.
order new remote
Posted on Mar 14, 2009
  • 45 Answers
SOURCE: Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Posted on Jun 09, 2009
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
  • 34 Answers
SOURCE: I have a Panasonic CS/CU-W18DKR - on cooling it
When the unit heats inside, the outdoor unit cools, and if the outdoor cooling coil gets too cold the system turns off indoor fan, and changes gas flow direction to de-ice the outdoor coil. Ensure both coils, and the filters are clean and if there is still a problem check system gas pressure for leaks.
Posted on Apr 24, 2010
hvac1960
  • 2133 Answers
SOURCE: FAULT CODE H19? WHST IS
H-19 Error code means indoor fan mechanism locked. replace fan.
Posted on Dec 12, 2010
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
Panasonic cs-c9dkh air conditioner
I have problem with aircond Panasonic CS-C9DKH..5minit after start they stop automatic.Why this happens..The cooling fan also not running.It's because of fan or PCB.Please help me.......
Nov 17, 2012 | Panasonic Heating & Cooling
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Problem with panasonic cu-s10hkh air conditioner outdoor cannot run
It is likely equipped with a temp sensor that only permits the fan to run when the compressor reached a certain temp. If the unit is short cycling then obviously there is a problem. Likely in that sensor. Good Luck.
Jan 12, 2012 | Panasonic Heating & Cooling
Panasonic AC Model CS-A28BKP5 remote not working. Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off...
If receiving signal in unit and calling signal in remote should be functioned properly. If any one of these, defective you can't operate by remote.
In your case, it's receiving signal in PCB is weak or defective. You can repair/replace only that portion. Call repairman to arrange for it. Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
I have a Panasonic CS/CU-W18DKR - on cooling it works fine, auto aswell as fan, but on heating when it is on manual fan control it used to blow all the time, but not for some reason it only blows...
Apr 18, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
