Hdd not accessible in formatt process,but other hdd run.
  • 33 Answers
HDD is only inaccessible in format? Can you see the content? If not do you have content you need to backup? If so i would sugest recoreing it first and then sending it to the HDD brand copany for RMA
Posted on May 20, 2011
Hp-m3035 that says no drive installed
the hard drive should be located at the rear right side ( service access panel) remove this and open the formatter grounding case - there you should see a 10 / 40 gb laptop style Hdd -the connections may be loose- the Hdd may be dead- unplug the re connect all Hdd connectors and try again- if that doesnt work you'll need to replace with similar type and on power up enter the service mode and initialize Hdd- then on ready - setup the printer as new .
Mar 06, 2014 | HP LaserJet M3035xs MFP All-In-One Printer
Sd card password lost
Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Download and install a file explorer application, such as FExplorer, X-plore or Best Fileman onto the mobile device. http://download.cnet.com/f-explorer/3000-2094_4-75758737.html Run the application on the mobile device. Select the "Find" option. Type "MMCSTORE" in the space provided. Connect the mobile device to the computer via either a Bluetooth connection or the connection cable that came with the mobile device. Send the "MMCSTORE" file to the computer. Rename the "MMCSTORE" file "MMCSTORE.txt" on the computer. Open the "MMCSTORE.txt" file on the computer. Write down the password located in the "MMCSTORE.txt" file. b> Using a PC b> Download and install the SD Formatter program from the SD Association website. http://www.sdcard.org/consumers/formatter/ Insert the SD card into the computer's SD card reader. Run the SD Formatter application. Select the SD card from the drop-down menu and click the "Format" button. Formatting the SD card will reset the password. However, the process also will remove any data that is stored on the card. Allow several minutes for the SD card to format. Hope this helps.
b>
Dec 29, 2012 | Computers & Internet
How to unlock micro sd memory card, when i forgot my password
Recover an SD Card Password b> Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Sep 14, 2011 | Kingston 2GB Secure Digital Memory Card
My hdd detected in cmos but during formatt process its show not accessible,and when i boot my computer the screen show LGIBM logo.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 20, 2011 | Computers & Internet
My hp t770 have this error 59.2:00 after repalcing formatter board plz help me
A 59.2:00 error says that a reused part has been installed.
If you paid for a NEW formatter get your money back and shop somewhere else.
If you paid for a repaired/reconditioned part, it won't work.
You need a NEW formatter.
Mar 18, 2011 | HP DESIGNJET T770 Printer
49.4c18 error
This is a formatter error!
Process to resolve:
Unplug the power cord from the machine, and leave it disconnected for about 10 minutes. Plug it back in and power on.
If the error still persists you will need to replace the formatter. Formatter errors occur mostly when sending over .PDF files if it's a communication based issue. However the P3005 are notorious for having the formatters go bad.
Jan 09, 2011 | HP LaserJet P3005 Printer
My sata 500 gb hdd is hung, office 2010 not working, how can i formatt hdd,(loosing data- no problem, have backed it up already)
you might try this before you format your hardvdrive uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Dec 03, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
I have a three month old Toshiba 1TB external HD. buy now it decided not to allow me access and asks me to Formatt the Drive. I do not want to lose my data......!!! What do I do
had one do that,,,try plugging in another usb slot c if it does it,,,also reboot with it pluged in ,,c if that helps,,if not go online to toshiba site,,may be others with that prob,,k
Oct 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Gigabyte Slot 1 GA-6BXC Start Up UnStable
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
May 27, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Usb problem
no fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
May 17, 2008 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
