Question about Canon PowerShot A590 IS Digital Camera
Hi, I have cannon powershot 590. My camera is in the lens extended position and are not moving into the camera, There is a message on the LCD screeen "lens Error". Please guide me to solve the problem. Thanks
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on May 28, 2011
I turned my Cannon G9 camera on and 'lens error. restart camera' is the message I see. The lens will not retract and the camera does not function at all except for the message and the opening...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 31, 2011 | Canon PowerShot G9 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
E18
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
The problem usually happens because dirt or sand get into the lens mechanism. To repair it, visit this link and follow all the steps.Rating the solution is highly appreciated..
May 25, 2010 | Canon PowerShot A75 Digital Camera
Cannon powershot SD1100 IS it displays the
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E18 on Canon Powershot A95
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
