Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
When i plug in my wd5000mes(500gb), its light flashes on. then it says device driver software was not successfully installed. then it appear as a unidentified device. nothing appeared in my computer. please advice me something on this matter because i have realy important data in this disk. i was using it from last 1 year.
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 20, 2011
My tablet usb will not work
Try plugging in the USB cable between the tablet and the USB port of a PC. The PC should recognise and install the correct driver software.
On the Tablet you need to choose between "debugging" and memory flash disk. Choose the Memory flash disk option on the screen.
The Tablets internal drives will then appear as drives on the PC if successful.
Some PC's cannot install the correct driver software, so you will have to download a generic android one from the Internet.
Apr 01, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Micro sd adapter driver
"device driver software was not successfully installed"
Find the correct driver for your computer and operating system.
Mar 17, 2014 | Kingston Electronics - Others
Win 7 detects PQI USB flash drive 8GB but not successfully installed due to no driver found
It is probably faulty in that case if other USB items work in the same port.
Sep 30, 2017 | Computers & Internet
I got a behringer c-1u mic and I plugged my USB in the pc and it says no drivers are installed for this device and also the green light of the mic flashes soon as u connect it then dims out and stops...
Either you haven't yet installed the drivers (usually a CD that comes with - or can be downloaded from Behringer Website),
AND/OR your bios settings dis-allow plug-and-play USB devices. Restart your PC and enter Setup to check..
AND/OR your microphone is bad, have you had success with it on another PC?
AND/OR your USB Port is bad - are you plugging directly into the PC's USB, or a seperate multi-port Hub? I once had a multi-port USB Hub that burned up anything I plugged into it.. Took me about 3 devices to die before I simply changed the hub. Pwoblem solved..
Hope this helps...
May 03, 2012 | Computers & Internet
Problems with d-link DWL-G650 wireless cardbus adapter pcmcia
You can try downloading the latest driver for this card from Dlink web site and then remove the previously installed software and install the one that you have downloaded and then check if everything is working....
Dec 14, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
Segate 1TB not working with Windows 2003 Server
Is this an internal disk, or an external backup device? Two possible routes:-
Internal disk:-
Ok first thing: Does the BIOS see the drive? If not, try flashing the Server's BIOS to the latest version. Check that the system will support disks >500Gb. Try turning on LBA in the BIOS. It shouldnt affect it, but has been known to.
If its not showing here, its either faulty, dodgy cables, or not supported.
If its visible in the bios, great. Make sure you have at least one and preferably all the service packs installed. Gold (RC) only supports 500Gb drives.
Make sure you have Chipset drivers installed for the mobo. If its visible in the disk management console, then create a small disk, NTFS.
External backup device:-
Either you will need to install the software in 'compatibility mode' for xp, OR
dont use their software at all. Just plug the disk in, and it should appear as a removable device. Then use the windows backup tool to create a backup file on the external disk, and run a backup using that.
Jul 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Logitech PRO 9000 installation failure
Click off on the FOUND NEW HARDWARE and continue the installation.
If you have further problems, let me know and I'll assist you to get it going.
Hope this helps. Bud
Feb 01, 2009 | Logitech QuickCam Pro 9000 Web Cam
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
253 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
