Kyocera Printer is not printing. Error is "Add Paper. Letter"
    Problem Solver:
  • 5 Answers
This is a common error due to many printers set default paper printing size as a letter size, and you don't have it in printer.
You need to set the output paper to the one that you have (I guess it is an A4) in advanced setting on the printer.
Hope this help!
Posted on May 20, 2011
Why does our Kyocera Taskalfa 181 keep displaying a "Print mode error" message?
It is usually because you have the machine set up as A4 and the your documents or printer driver set to 81/2 X11(American letter size) size paper ,to override this ,got to the menu system button in the top left of the operation panel ,scroll down to printer setting in one of those menues you'll find A4/letter override turn it on and you'll get rid of the problem .
Apr 21, 2015 | Kyocera Office Equipment & Supplies
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Red light blinking
Clear the print que. Sounds like you have a print job in the que that has a European paper size. Example A4. U.S.A. useS 8.5x11 or letter or letter (r)
Apr 15, 2014 | Kyocera FS-920 Laser Printer
Kyocera km-2050 print mode error
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
Dec 31, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
ERR CODE E-0007 IN KYOSERA FS-1020
This question (which is factually not a question) needs more information. When does this happen?
Possibly an updated code. I can find E07 for Kyocera which means the printed document size/format does not match current paper size/format. Like you want to print A4 on Letter paper.
Nov 20, 2013 | Kyocera Mita FS-1020D Laser Printer
Print Error?
You are more than likely sending it a print job for an incorrect paper size..ie American fullscap or letter if you are European.
Press the print button on the copier and it will tell you what the problem is.You can try loading paper into the MFP tray and pressing go-should work.
Jun 06, 2013 | Kyocera Mita KM-1650 All-In-One Printer
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
48 people viewed this question
k24674
jasbo
jasbo
