Question about HP LASERJET M5035 MFP All-In-One Printer
49.4C02-Error to continue turn off then on. - HP LASERJET M5035 MFP All-In-One Printer
  • 37 Answers
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
firmware operations.
NOTE In many cases, turning the
power off and then on will
permanently clear most 49 errors.
In some instances, electrical noise in the
cable can corrupt data during transmission to
the device. Other causes include poor-quality
USB cables, poor connections, or specific
software programs.
1) Upgrade the firmware.
2) If the message persists:
Turn the MFP off.
Remove the DIMM.
Remove any installed EIO devices.
Turn the device on.
If the error message disappears,
reinstall the DIMM and EIO
devices individually, making sure
to turn the device power off and
then on again as you install each
device.
g. Replace the component that
caused the error message.
Posted on May 20, 2011
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
  • 17 Answers
SOURCE: problem with our printer 5200tn
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
vendor for assistance.
Posted on Dec 18, 2008
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
  • 48 Answers
SOURCE: Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Posted on May 25, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
The printer will not print because of service error 49,4c02
Hello thanks for using FixYa
error 49.4c02 is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
Please see my this Solution (Same as your's), 2 people thought it as Helpful for them So
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 10, 2011 | Office Equipment & Supplies
How to fix E1 error on samsung ER 5140
E1 is just operator error, it normally occurs when the wrong keys are pressed or the machine has got itself into a bit of a loop. At exactly which point does the message appear? is it when you press a certain key?
The first thing to try is an initial clear:
Turn the key to P
Press and hold SUBTOTAL
Whilst continuing to hold SUBTOTAL turn the power off... then back on
Continue to hold SUBTOTAL until the receipt stops printing
Turn the key to R and give it a test.
Nov 13, 2010 | Samsung Office Equipment & Supplies
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
occurred that caused the
to abort operation. This type
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
programs and print jobs,
disconnect all of the
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
off and on again as you
install each device.
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP LASERJET M5035 MFP All-In-One Printer Logo
4,498 people viewed this question
Seeker5211
Seeker5211
