Question about Gaggia Classic Brushed Stainless Steel Espresso Machine
Hi I have gaggia classic cofe machine. It is used once in a week. Two weeks ago my gaggia stop pump woter in to coffe mug. Just like its not strong to pump water thru all the system. Never have this problem befor. Sorry for my english, its not my firls language:)
    President:
  • 1,618 Answers
Remove the screw and shower screen, make sure screen is clean and you can see through all the holes in it, if not set screen on the stove (open flame) to burn out the coffee oils in the filter. The coffee will burn before the screen gets any damage. When done you should have a new screen reassemble and test.
Posted on May 20, 2011
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
I cant get the coff strong it seems very week
Too many variables to answer reliably.
What coffee? How Old? Pre ground or beans? How much coffee? How long does extraction take? Water temperature? Try to narrow the questions to areas.
Feb 19, 2015 | Gaggia Coffee Makers & Espresso Machines
Why is my coffe machine dispensing little aluminum particles in the water?
I HAD THE SAME ISSUE BEFORE I SWITCHED TO FILTERED WATER AND WASHING PLASTIC RESERVOIR BASKET EVERY WEEK. TRY.
Sep 12, 2014 | Gaggia Classic Espresso Machine
Gaggia Classic won't turn on, no light at power switch
I would suspect rough handling of your suitcase, leading to some loose or broken connections inside. I recommend opening it up and looking for obvious disconnections. If you don't see any, the next step will be to use a tool like an electrical continuity tester (which can also test for a blown fuse). There is a lot of information about Gaggia Classic repair online -- just search for "Gaggia Classic repair".
Jul 29, 2013 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Same problem with my classic gaggia.
Hi Marc
Just bought one this week with exactly the same problem. As a last resort I opened it up to find the pump had come off the rubber support kinking the pipes beneath so no water could get in.
Undo the 2 philips screws on the top, take off the lid and water filler spout and take look. Looking down from the front of the machine, the pump is at the back to the left. If it's just floating in space as mine was, simply push it gently back into the rubber support beneath making sure you don't kink the pipes.
Mine came by DHL from Italy with no right side up marked on the box, so no wonder it came loose!
Hope this fixes it.
Matt
Aug 25, 2009 | Gaggia Classic Espresso Machine
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Brushed Stainless Steel Espresso Machine Logo
147 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
