Question about LG Heating & Cooling
Hello I have a 26 BTU LG split unit AC the capacitor in the compressor unit need to be replaced but I don't know how is the wiring connection the capacitor has three heads remarked as follow: fan----- common------- herm could you please support me with a wiring drawing for the capacitor
    Guru:
  • 683 Answers
Hi, The Capactor that you are talking about is a dual capactor. It works the fan and the hermitic compressor in one. The leg common is power into the capictor, The fan leg goes to the outdoor fan, the herm leg goes to the compressor. Good advice is when you change the capacitor you should also change any other start componants that are also there. I hope this helps.
Posted on May 20, 2011
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Fuse keeps blowing on my Whynter portable ac
Is your compressors motor capacitor replaceable? I know that on a split system, a dead capacitor (typically a 35uF) can cause increased current draw, to the point of blowing fuses, though I've never had to replace one on a portable unit. I usually replace them with a 30uF capacitor, roughly the size of a "200ml can of softdrink".
Apr 11, 2014 | Whynter ARC-14S ECO-FRIENDLY 14000 BTU...
The ac trips the breaker in the camper when the compresser comes on
Check that incoming voltage is up to specs at AC unit control box ( 110-120VAC ), and if good, I'd suspect start capacitor for compressor is defective and needs replacing provided compressor is good. Usually a new capacitor is required in most cases. Please don't try changing it yourself if not experienced in that area, as capacitors can give a very high voltage shock, even with power off.. Don't forget to turn breaker off to power source before working on it.
Jun 28, 2011 | Coleman Mach III Air Conditioner
I have a Trane unit 2 Ton that was washed down with the unit running. Was told unit compressor changed tunes while doing so. i suspect the compressor is shorted since it will not come back on , fan is...
A 'short' would be indicated by a breaker tripping or a fuse blowing at the time you turn on the unit, so I don't think you are dealing with a short. Since the compressor is a 'sealed unit' it's doubtful if you harmed it. However, washing down an AC with it running is not advisable and in fact is very dangerous. Electricity and water do not mix and a person can easily electrocute himself/herself doing this. That being said I would make sure the entire unit has dried out and with all power off - then 'inspect' all the electrical components - i.e. wire connections and 'starter relay' to make sure everything is in good condition. The fact that the fan is running indicates the 'starter relay' is ok - again - I would check all the electrical components, especially where the wires connect to the compressor. My guess is you have a wire burnt off of the compressor which probably happened while the unit was being washed.
Jun 06, 2011 | Heating & Cooling
I have a Goodman split model from around the year 2000. It sounds like the compressor tries to come on for about 2-3 seconds and then stops. The green light on the inside portion stays on stead but after a...
The compressor start capacitor may be bad or the compressor it's self is bad and cannot get started...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 24, 2011 | Heating & Cooling
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Split AC capacitor fused.
You need to trace the wires back to the device ie compressor, the fan now then write the color down. Note the capacitor has two different sides to it herm which is compressor and fan. then the common in the middle. Take the compressor wire should only be one and connect it to the herm. Now take the fan should only be one again and connect to fan. two devices connected. You might have two more wires and they go to the common. If you need any more help just get back to me. ken
May 09, 2010 | Samsung AW0603B Air Conditioner
Electrolux split AC 1.5 ton inside fan working.But out side compressor fan stops after two or three rotations.
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's hot out. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Mar 21, 2010 | Heating & Cooling
LG ac M483CS not cooling
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Feb 02, 2009 | LG LSC183VMA Split System Air Conditioner
Hi, I own a split a/c 12000 btu, the problem is that the last two days it kicks down the fuse. this happens when the compressor tries to start. the a/c was working fine for the past three years. do you...
i think the problem would be the compressor. unplug the unit and if you know how to test the resistance of the terminals, then do a ground check on the compressor. if it is grounded, then it is broke. if not grounded, then observe it as it runs if it would start, if it can not start then you still have to check the starting components such as the capacitor and the wirings associated with it.
tnx for using Fixya
Drcool
Dec 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
