Question about Honeywell Programmable Thermostat Heater
Brivis buffalo 85 EMS . pilot ignites, then main gas burner comes on only for a few seconds, and repeats itself . red led light comes on EPRL.
  • 2 more comments
  • redrosebulld May 20, 2011
    pilot light ignites, then the main gas burner lights .but only for a few seconds, then the cycle repeats itself, after which the fan comes on .then an LED light comes on [EPRL] .the reset is pressed and the same happens. Brivis buffalo 85 ems.
  • redrosebulld May 21, 2011
    this type of system as no thermocouple, it operates on a flame rod type device [flame rectification] that once the pilot is establised it puts power on the main gas valve to operate, i mainly work on B type heating systems and not done any domestic work for 15 yrs . Brivis are difficult to work with and unless you are brivis certified they will not come to the party
  • redrosebulld May 24, 2011
    the solution was not helpfull. there is no thermocouple on this unit , it has a flame rod with auto ignition and flame sense. thanks for nothing,[ can i have my money back] . Not happy
    Genius:
  • 1,157 Answers
Hi redrosebulld,
If the EPRL light still flashes most likely the thermocouple has worn out. The thermocouple is a safety device which stops the gas from flowing. I will recommend to consult an authorized repairman to check the thermocouple and also the injector.
Hope it helps.
Thank you for using FixYa.
Posted on May 20, 2011
    Guru:
  • 1,833 Answers
According to your problem, first check the electric input & outlet. Check the gas connection. You may need to reset it. Reset the timer properly & the time zone also. It may help you.
  • 3,740 Answers
The electronic controller is shutting of the main gas valve. There are 2 themostats in the system that the controller uses to sense heat. One is the 90 Deg thermostat and the other is the overheat thermostat
The PN's in quesion are:
2500121 the Controller
2501440 Thermostat
2501442 Thermostat
1319855 Thermostat is for the fan motor only and should not effect the burner operation
See this manual link below page 25 for parts listed above.
http://www.reece.com.au/new/pdf/products/Reece_Gas_Reference.pdf
The 2 thermostats need to be tested for continuity when heated. No continuity when heated with a match = failed themostat.
^-- I am having a bit of memory fade here but you will only have continiuty when either the thermostats are either cold or HOT but not both.
For sure the owners manual below is of no help at all.
http://www.brivis.com.au/upload/data/Owner%20Manuals/classic_manual_owner.pdf
Thanks for choosing FixYa,
Kelly
Posted on May 21, 2011
  • Kelly
    Kelly May 26, 2011
    I did not mention thermocouples at all... I take it my solution was not tried. No worries here... I was just trying to help. If you still have issues with FixYa click on contact located at the bottom of this page rt side. The menu will guide you after that.
    Kelly
I have a brivis buffalo 85 ducted heating system, from last few days it doesn't come hot air only fan is running. pilot lamp also not with flame. ignation is working. I was turm blue color lid to pilot...
you need a new thermocouple. u can either get one from a plumbing store but the can be a bit fiddley to fit or u can get the proper Brivis one it just pulls out and u put the new one in. then u have to re light the pilot light. make sure u hold it down for at least 45 sec to make sure that it is getting hot enough when u release it it will stay alight then turn gas valve to the on position
May 26, 2014 | Heating & Cooling
I have a Brivis Buffalo 85, pilot light is on main burners will not ignite when turned on? It seems like gas isnt allowed to bar which turns on main burners
Usually a thermocouple or similar device is employed to allow fuel to flow once the unit sees that there is sufficient heat to ignite the fuel. Otherwise it can be a fuel valve that "sees" an unusual flow of gas which sets off the safety.
May 07, 2014 | Honeywell Programmable Thermostat Heater
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
Brivis Buffalo 15 not blowing air.
This sounds like a flame proving fault, so what's more than likely happening is the unit isn't sensing the flame. You'll see a small metal rod sticking down infront of the burner on the opposite side as the ignition source. Remove that rod, and clean it with some scotch bright. If you know how to work a volt meter you can test this part. Take the wire off the flame rod, place your meter leads in series with the wire and flame rod and set it to micro amps DC. Fire the unit up, and when your main burner lights you'll want to see a minimum of 1micro amp DC. If you're getting a higher reading than that and it still cycles I'd be suspicious of the grounding of the burner, or the ignition control! Good luck, let me know if you need any more instruction!
Apr 18, 2013 | Heating & Cooling
Brivis Buffalo 85 loud bang.
short blocked pilot needs cleaning burner blocked needs cleaning
Jun 04, 2012 | Heating & Cooling
When main gas valve opens to start burners the gas pauses then ignites with a high volume woof.The pilot flame looks a little small could this be the issue. This unit is Brivis Buffalo year 1988 model...
The problem is called "Delayed Ignition". This can be caused by burner & pilot obstructions (dust, lint and/or pet hair) and needs to be thoroughly cleaned. At 23 years old, I'm surprised the unit is still in service.
Hope this helped you to troubleshoot and solve the problem.
Apr 28, 2011 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Brivis buffalo 85 with EMS2 would not fire up
Hi Long Bob
I am having the same problem. Did you find out what was the cause?
Cheers
Chris
Jun 30, 2009 | Honeywell Programmable Thermostat Heater
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Heating & Cooling Logo
1,747 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
