Question about Dryers
I can run my drier but after a few minutes it begins to smell of burnt wires
I put my drier all back together and will run it until it quits; that way I will be able to find the problem. I am just ahead of myself. I think now that it is the element burning out and it will eventually burn right out; then I'll replace it.
Thanks.
Posted on Aug 17, 2008
When several burners are lit i smell fumes that after a few minutes actually begins burn my eyes. What should i do?
Switch it off and call a gas technician. That may be Carbon Monoxide also known as 'The Silent Kille**r'. It could also be an indication of not enough air being burnt with the gas.
Jan 11, 2017 | Heating & Cooling
Works alright after few minutes I get burnt smell
You have to check and replace check the carbon brush of the motor. After that check the treadmill.Also check is the motor get hot while running . if the smell remains the you have to go for a new motor.
www.electro-medical.blogspot.com
Oct 01, 2015 | Exercise & Fitness
Burnt wire smell Board Flashing Br
The unit was running when we came in. No Storms in the area. it was blowing hot air, but was still on the cool setting. There was a burnt wire smell coming from the unit. And the diag. code was Br. I found this odd since it still had power.
Aug 16, 2014 | Amana PTH153B50AM Air Conditioner
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
A bad smell (like a chemical) was coming from the frig but it was still working fine. Repairman couldn't find anything - other than saying it smelled like burnt wiring. Then a few days later, the...
There is a stile heater around the door opening and sounds like it shorted out. This would be the smell you noticed. The plastic door trim should have felt exceptionally warm to the touch
Aug 01, 2011 | Turbo Air MSR-49NM Refrigerator Commercial
Intermittent fan motor & relay switch (4-5 sec.) - warm freezer
you need a new overload contactor or they call them an RTX also that powers the compressor it is located on the compressor body,also replace the capacitor that plugs into the RTX at the same time you replace the RTX that will solve your problem
Dec 24, 2009 | GE Refrigerators
When the heater is on, it begins to smell like ammonia. It did not do this last year
If you have run the a/c during the summer particles of dust and debris stick to the electic coils and once they are activated the smell is the debris that has accumulated on the heater coils. Run the unit for a few minutes and the smell should subside.
Good Luck
Dave
Dec 07, 2009 | LG Heat cool Window Air Conditioner
My kenmore dryer will run then stop after a few minutes
this sounds like it is overheating all driers have a thermatic switch that will kill the drier if it over heats, probably wouldnt hurt to call out a repairman from sears on this one.
Dec 31, 2008 | Kenmore 62602 Electric Dryer
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Dryers Logo
63 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
