Question about Cub Cadet Garden
MY CUB CADET LTX 1040 IS PROBABLY A 2009 MODEL. IT WILL START FINE BUT WILL START TO STUMBLE AND DIE WHEN I RELEASE THE PARKING BRAKE OR WHEN I TRY TO ENGAGE THE PTO TO OPERATE THE DECK BLADES. --THIS MAY BE A RESULT OF MY REMOVING THE DECK AND HAVING A PROBLEM THERE WITH THE DECK ENGAGEMENT \r\nCABLE SET UP, THE ONLY WAY THAT I COULD UNDO THE SPRING WAS TO REMOVE THE BRACKET AND TO BE TRUTHFUL , I WAS NOT 100% SURE THAT I REINSTALLED IT CORRECTLY.---AS I SAID ---IT STARTS UP FINE BUT WILL SPUTTER AND DIE WHEN I RELEASE THE PARKING BRAKE OR WHEN I TRY TO ENGAGE THE DECK BLADES. WHAT IS MY FIX ??
  • 3 more comments
  • IRONMAN1954 May 20, 2011
    THE ADVICE FROM THIS RXPERT DID NOT TELL ME ANYTHING THAT I DIDN'T ALREADY KNOW.MY WIFE COULD HAVE TOLD ME THE SAME THING. I WANT SPECIFICS NOT GENERALITIES.IF I HAD WANTED TO GET IT LOOKED AT BY A REPAIR SHOP, I WOULDN'T BE ASKING YOU FOR ADVICE.I WANT SPECIFICS! PLEASE
    ALL THE INFO GIVEN HERE IS CONTAINED IN THE OWNERS MANUAL----I TRIED THEIR FIXES BEFORE I CONTACTED YOU PEOPLE, WHAT I AM EXPECTING FROM YOU IS ---FIRST DO THIS AND THEN DO THAT AND THEN YOUR PROBLEM WILL BE SOLVED-----IF WE CANT DO THAT, LETS FORGET IT--I AM NOT SATISFIED WITH YOUR HELP SO FAR
  • IRONMAN1954 May 21, 2011
    JIM,YOUR ANSWER SEEMS TO BE A LITTLE MORE INFORMATIVE THAN THE OTHERS. ARE YOU PIN-POINTING THAT SEAT SWITCH AS THE PROBLEM-----NO--I DIDN'T DISCONNECT ANY ELECTRICAL SWITCHES. I DID DISCONNECT THE DECK ENGAGE SWITCH BY FIRST REMOVING THE BRACKET WHICH IS BOLTED TO THE DECK. I AM FAIRLY CERTAIN THAT I REINSTALLED IT CORRECTLY.THAT PARTICULAR CABLE IS
    SHEATHED AND LOOKS ELECTRICAL BUT IT ISN'T. IT IS ABOUT A 1/16" CABLE THAT SNAKES AROUND FROM THE DECK --UP AROUND THE BACK OF THE TRACTOR AND ENDS UP ATTACHED TO THE PTO LEVER--IT MOVES A PLUNGER IN OR OUT.--UP NEAR THE PTO LEVER---I CANT SEE IT BUT I CAN FEEL IT ----BACK TO THE SEAT SWITCH---I AM NOT QUITE SURE WHAT YOU MEAN THAT IT PREVENTS THE TRACTOR FROM RUNNING WHEN NO ONE IS SEATED----MY TRACTOR WILL START AND THE ENGINE WILL BE HUMMING ---WITHOUT ME SITTING IN THE SEAT--THE PROBLEM IS THAT THE ENGINE WILL BEGIN TO STUMBLE AND DIE WHEN I BEGIN TO RELEASE THE PARKING BRAKE---SAME WITH THE PTO LEVER----NOTE THAT I AM NOT SEATED IN TRACTOR SEAT WHEN I AM DOING THIS--I AM STANDING ALONG SIDE THE TRACTOR. DO YOU THINK IT WOULD ACT ANY DIFFERENTLY IF I WERE SEATED IN THE SEAT?
    1. JIM,YOUR ANSWER SEEMS TO BE A LITTLE MORE INFORMATIVE THAN THE OTHERS. ARE YOU PIN-POINTING THAT SEAT SWITCH AS THE PROBLEM-----NO--I DIDN'T DISCONNECT ANY ELECTRICAL SWITCHES. I DID DISCONNECT THE DECK ENGAGE SWITCH BY FIRST REMOVING THE BRACKET WHICH IS BOLTED TO THE DECK. I AM FAIRLY CERTAIN THAT I REINSTALLED IT CORRECTLY.THAT PARTICULAR CABLE IS SHEATHED AND LOOKS ELECTRICAL BUT IT ISN'T. IT IS ABOUT A 1/16" CABLE THAT SNAKES AROUND FROM THE DECK --UP AROUND THE BACK OF THE TRACTOR AND ENDS UP ATTACHED TO THE PTO LEVER--IT MOVES A PLUNGER IN OR OUT.--UP NEAR THE PTO LEVER---I CANT SEE IT BUT I CAN FEEL IT ----BACK TO THE SEAT SWITCH---I AM NOT QUITE SURE WHAT YOU MEAN THAT IT PREVENTS THE TRACTOR FROM RUNNING WHEN NO ONE IS SEATED----MY TRACTOR WILL START AND THE ENGINE WILL BE HUMMING ---WITHOUT ME SITTING IN THE SEAT--THE PROBLEM IS THAT THE ENGINE WILL BEGIN TO STUMBLE AND DIE WHEN I BEGIN TO RELEASE THE PARKING BRAKE---SAME WITH THE PTO LEVER----NOTE THAT I AM NOT SEATED IN TRACTOR SEAT WHEN I AM DOING THIS--I AM STANDING ALONG SIDE THE TRACTOR. DO YOU THINK IT WOULD ACT ANY DIFFERENTLY IF I WERE SEATED IN THE SEAT?
    Next
    JIMS SOLUTION WAS THE BEST ONE THAT I RECEIVED --SORRY TO SAY THAT I CANT TEST HIS FIX BECAUSE MY BACK WAS UP AGAINST THE WALL AND I NEEDED TO GET MY TRACTOR RUNNING. I HAD IT TRAILERED TO A REPAIR SHOP .
  • 797 Answers
The problem is most likely the interlock safety that prevents the riding mower from running when no one is seated. There is an interlock switch in the seat. Either the switch is defective or you have a break in the wiring between the seat and the rest of the system. Did you disconnect any wiring connectors when removing the deck? Did you get them back in the correct locations?
Jim
Preston Comptuer Services
www.prestoncomputerservice.com
Posted on May 20, 2011
  • James Preston
    James Preston May 21, 2011
    Yes, all modern (since at least the 90's) have had a safety switch in the seat that prevents the mower from moving or engaging the mower blades when no one is seated in the tractor seat. This theoretically prevents you from being run over or sticking your hands in the mower blades.
    Check what happens when you are seated in the seat.
    Note, it does take a certain amount of weight so .... do not try to fool it with a weight.
    Jim
  • 5,370 Answers
As per the problem you mentioned, its indicating towards switch problem.The seat switch is getting short so the engine dies as you release parking brake.But there are many other possibilities if seat switch checked ok,.To go through other possibilities and deck engagement belt replacement procedure please click the link below:----
http://technoanswers.blogspot.com/2011/05/cub-cadet-ltx-1040-will-not-start-and.html ------------ This should help.Thanks.Helpmech.
  • raj somaiya May 20, 2011
    Did you checked the seat switch.Also whats the voltage of seat switch.Keep updated.Thanks.Helpmech.
    President:
  • 2,047 Answers
Considering the events leading up to the problem the fix is to get the deck engagement cable setup. Once you get the cables setup properly the unit will not give you the said problem anymore. When the bracket is not properly fixed the cables end up being poorly connected and cause poor contact and therefore flow of fuel through the system becomes inadequate as the cables are not acting as expected due to the poor fix. With the description given there could be a ton of other things which could have gone wrong with the system due to continuous trials. Try to get an expert look at it and assemble it properly to ensure that other damages dont happen to the unit as continuous trials could only worsen the situation.
Hope this solution has been helpful?
Where is the 20 amp fuse located in a cub cadet ltx 1040?
The manual for the Cub Cadet LTX 1040 is posted at https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/2010_LTX1040a.pdf
On page 28 under "Fuse," it says that the 20-amp fuse "is located under the hood, mounted behind the top of the dash panel on the support bar."
Nov 09, 2015 | Cub Cadet Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Did you mean: i have a cub cadet 1040 ltx that is running rough and loud?
Head Gasket possibly
You should be able to find out where
the noise is coming from
Oct 11, 2014 | Cub Cadet Garden
I have a cub cadet ltx 1040 everything cranks and
bad safty switch on brake replace it says the red neck
Sep 24, 2014 | Garden
Trying to jump (with my car, I know it's not good) my cub cadet LTX 1046. Worked a few times. Now the parking brake light comes on when I try to turn it over and the motor won't even try to start. Nothing....
Find the switch attached to the parking brake mechanism. It's probably stuck. Jumping with a car will not hurt it if it uses a 12 volt battery. The car is not "too much power" for it. The mower will only take what it needs.
Nov 03, 2013 | Cub Cadet Garden
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
My Cub Cadet LTX 1040, has no power to anything and will not start
check the battery cables bypass them with your jumper cables the check the safety switches
Apr 12, 2012 | Garden
Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
May 04, 2011 | Garden
Garden Logo
735 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
