Question about Sony Playstation 3 (PS3) Console
PS3 HDMI Audio Problem
I want to use HDMI to send video to a projector and use the optical digital output for audio (separate system). PS3 doesnt seem to want to allow that. This arrangement works fine with my DVR box. I have set the PS3 internal audio/HDMI settings to every conceivable combination. The optical shows that it is on but no signal to my preamp (9000ES).
  • 1 more comment
  • bobfell Aug 14, 2008
    I hope this is not a Blu-Ray standard! Very inconvenient.
  • B4300 Sep 27, 2008
    My PS3 will only play blue ray video,,no audio.. I have an Onkyo 705 ... no problem with my Direct TV audio.. any suggestions?
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    I have the same setup, hdmi for vid to tv, and fib opt for audio from the ps3 to my receiver and it works fine. So your settings or your receiver are not set correctly
The settings on your PS3 may be to high for your TV. try turning off your PS3 and turning it back on, when you turn it on hold the power button untill it beeps aprox 10 sec. this will reset the your PS3 back to original (minimum settings)
Posted on Nov 23, 2008
There is no sound coming through my HDMI/DVI cable. is there any other way to get sound?
Try going into the audio setup of your PS3 to make sure you have it set to send audio down the HDMI. The PS3 allows you to send the audio down the HDMI, standard, or optical, but you have to change the settings.
Along the same lines, you can use an optical cable to run it to a receiver (or your tv if it has an optical input). Just remember to change it to the optical output.
I don't have the PS3 in front of me right now, but go to this link and it will explain it to you:
Thanks for reading and good luck.
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
Select [Audio Output Settings].
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
back of your player.
3Connect the other end of the cable to the
the digital audio system.
Aug 11, 2017 | Televison & Video
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
No Audio
May 19, 2008 | Sony Playstation 3 (PS3) Console
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
Sony Playstation 3 (PS3) Console Logo
487 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
