Question about Homelite Garden
Removing clutch and replacing with new clutch. How do you remove the clutch?
  • 675 Answers
First you need to remove the cover where the chain goes, then there is a clip to remove the clutch bell(thats the wheel looking thing that the chain is driven by)then there may be a nut that will allow you to remove the clutch pack...sometimes the clutch pack will unscrew of the crankshaft..depending on model..then replace and re-assemble in reverse order
Posted on May 20, 2011
  • 2 more comments
  • tomrenshaw May 21, 2011
    How do you keep the crankshaft from rotating when trying to unscrew the clutch?
  • meanween1
    meanween1 Nov 16, 2012
    jam some shoestring into where the spark plug goes in and pull starter till it locks....then lightly tap the clutch in a smart spot and it should spin loose with a couple light wacks,
  • meanween1
    jam
  • meanween1
    take out the spark plug and feed in some shoestring into that hole....pull the starter till it locks...then use a screwdriver or something and lightly tap in a smart area as not to break anything....a few light taps should spin the clutch off for ya
What has to be removed to get to the clutch
The transmission has to be removed. If it's a frobnt wheel drive car, the front axles have to be removed in order to remove the transmission.
The flywheel should be removed, too, and machined flat by an automotive machine shop. With the flywheel removed you may wish to replace the engine's rear main seal since it may leak oil.
The clutch often comes in a "key", which includes a new clutch pressure plate, clutch disk, and a "throw-out bearing" (used by the clutch fork to disengage the clutch). The kit may alos include a broze "pilot bearing", which is used to center the transmission's input shaft inot the engine crack shaft. The kit will include a placstic alignment tool to help the clutch disk while the new pressure plate is attached to the flywheel.
Aug 27, 2014 | Cars & Trucks
How do I replace a clutch 2000 eclipse
Remove transaxle. Remove clutch pressure plate. Remove clutch plate. Inspect the flywheel for damage and resurface or replace as necessary. Replace pilot and throwout bearings. Install new clutch plate. Install new pressure plate. Re-install transaxle.
Mar 06, 2012 | 2000 Mitsubishi Eclipse
95' ford econline 350 van replacing waterpump and clutch fan how to replace.
TO REPLACE WATER PUMP.REMOVE THE RADIATOR SHROUD HALVES.REMOVE FAN CLUTCH AND FAN.YOU NEED FAN CLUTCH WRENCH AND A FAN CLUTCH PULLEY HOLDER.YOU CAN RENT TOOLS AT AUTO ZONE OR BUY THEM AT A AUTO PARTS STORE.THE FAN CLUTCH BOLTS ARE LEFT HAND THREAD. REMOVE THEM BY TURNING CLOCKWISE.BEFORE INSTALLING NEW WATER PUMP COAT BOTH SIDES OF WATER PUMP GASKET WITH GASKET SEALER.TORQUE WATER PUMP BOLTS 18 FT LBS.
Mar 15, 2011 | 1995 Ford Econoline
Disassemble the clutch so I can install new primary chain
Isn't there a big nut in the middle of the clutch pack? Also I am not sure, it might be a left-handed one, check the threads first.
May 12, 2010 | 1993 Harley Davidson FXR Super Glide
Broken clutch lever replacement
You simply remove any rubber covering on the lever to expose the lever assembly. Remove its holding bolts/nuts. Disconnect the clutch-wire from the lever.
Put in new lever followed by other items you removed.
Nov 10, 2009 | 2008 BMW F 800 GS
Installing klutch
Buy clutch cover gasket
Unhook clutch cable at clutch cover
Remove clutch cover
Remove 5 clutch spring bolts
Remove springs
Remove pressure plate
Remove plates and disc noticing order
Replace with new plates/disc in same order (after soaking in oil for at least a few hours, over night would be better.
Put everthing back together in order of removal.
May 03, 2009 | 1997 kawasaki VN 800 A Vulcan
Need clutch replacement directions for Ford Ranger
Remove drive shaft,remove crossmember under transmission.Remove transmission and diconnect linkage.Remove bell housing,and clutch berring assembely.Remove bolts on pressure plate.Once this is done.Remove fly wheel for machineing.you will need a pilot shaft to alighn clutch assemblely.Possible one will come with new clutch and pressure plate.Reverse assemblely in same order remember to torque all your bolts with torque wrench.Take your time.
Apr 19, 2009 | 1994 Ford Ranger Supercab
How do you replace clutch in 1997 toyota corolla? Do you need to replace entire clutch assy or just the clutch disc?
I see. sounds like you need a new clutch. OK, here is a step by step guide to follow. it will help with the removal and installation of your new clutch.
Remove the Old Clutch Step1 Verify that your vehicle's clutch is the source of your problems and not the pedal-arm bushings, activating cables or the slave-master cylinder. Step2 Unhook the positive battery cable, the clutch cable or hydraulic slave cylinder to get the transaxle ready for easy removal. Eliminate anything that may hinder your efforts, including exhaust pipes and the speedometer. Step3 Secure your car in a safe position before jacking up the front end. Step4 Stabilize the engine with a jack below the oil pan. Remove the transaxle by undoing at least one engine mount. Step5 Separate the engine from the transaxle by removing the bolts that surround the flywheel bell housing. Step6 Push the transaxle away from the engine until the input shift clears the pressure plate. Step7 Disengage the bolts surrounding the pressure plate and take it and the clutch disc out. Check to see if the flywheel's friction surface is scored, checked or has hot spots. Remove, machine and reinstall the flywheel, if needed. Step8 Examine the pilot bearing (bushing) located at the flywheel's center to be sure the needle bearings are lubricated and that there's no galling. Also look for any oil leaking around the rear main engine seal. Replace the clutch Step1 Follow the instructions for replacing your car's clutch carefully to avoid having to remove the transaxle. Step2 Check that the transaxle's input shaft isn't leaking; replace if needed. Step3 Take out the flywheel and the old seal and install a new seal. Install a New Clutch Step1 Clean the crankshaft flange before putting in the flywheel. With the flywheel on top of the flange, secure the bolts in a star formation to the specified torque for your vehicle. Step2 Install the clutch disc and pressure plate. Prior to putting in the transaxle, attach the new release bearing to the release fork. The fork should move freely. Step3 Hoist the transaxle into position and move it forward until the input shaft glides into the clutch disc's spindled hole. Do not apply force. Step4 Reinstall any bolts or mounts that were removed to replace your car's clutch. Grab the transaxle, release the jack and lower your vehicle. Step5 Consider replacing your car's clutch cable. If you don't replace the cable at least adjust it for the right amount of free-play. Step6 Confirm that your clutch's self-adjusting action is performing correctly by depressing the slave cylinder's piston into its bore. Step7 Drive your car to be sure your clutch is working properly.
PLease rate and god bless:)
Apr 03, 2009 | 1997 Toyota Corolla
Garden Logo
834 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
