Recently i installed HDD seagate 80gb in my computer. since then i am facing a lot of problems. sometimes my computer show primary master hard disk fail, sometimes my hard drives disappear. what to do. i dont know any technical aspects of computer and am a layman to computer concepts. thus, it is my request if u can make me understand by step wise approach to the problem. thanks in advance.
    Sergeant:
  • 186 Answers
JUST CHANGE THE POWER PIN YOU HAVE CONNECTED TO THE HARD DISK AND PRESS IT FIRMLY.
PLS REPLY OR COMMENT. THANKS
Posted on May 20, 2011
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate 80GB hard disk
Dear
Your jumper setting is wrong.your elected is none ata compatible .plz set the jumper setting master or slave.
Jul 19, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 7200.7 st380011A 80gb when i use it as primary haerd dist operating system is not supporting it but when i use another hard disk as primary and it as secondary it is properly working....
i think you must place a jumper on the back side of the hdd.
If there isn't any jumper, it is a "slave".
When you place a jumper on the correct spot, the hard drive will become the master hdd. The position of the jumper can be found on the hdd itself.
Search for "master" and put the jumper there
Jun 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
I have a 2000 1100 series computer with a 37 GB hard drive thats out of space. I ordered a 80 GB and installed it but it still only shows the 37 when i go the my computer icon how do i clone the 80 GB to...
jjfsrm,
to clone ur 80gb,u must have a cloning software..
and if u wanted that the 80gb is ur first drive,u should install ur operating system on ur 80gb..and of corz the jumper on ur 80gb hdd must be on primary position,and for d 37 should be a slave..
ur 37gb is the first boot thats why it is on the primary,but if u put ur 80gb into primary,ur computer will not function well coz it does not have the o.s..
Apr 07, 2008 | Computers & Internet
Seagate barracuda7200.9 80 gig.
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Dec 10, 2007 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
David Payne
David Payne
