Question about Takara Car Audio & Video
Board fault takara car dvd players - Takara Car Audio & Video
I put a dvd in and it says reading but the disc isn't spinnng
Faulty or dirty laser, fault on decoder board or the motor the disc sits on is stuck of faulty
Sep 16, 2014 | Cyberhome CH-LDV1010A Portable DVD Player
I have a DVP642/37 player and after a power outage, the only thing that it will do is flash a red light on the standby button. None of the other buttons work. When I select the DVD player via TV remote,...
Hello
just unplug the DVD player from AC wall power socket, and lst it be in that state for at least 10 minutes and the replug and see whether it helps you. If not, the power supply inverter board of your DVD player is faulty. some fault are repairable, and some others are not. Anyway, it will be best to replace this board as card basis, rather than get it repair. OK.
Nov 02, 2011 | Philips DVP642 DVD Player
There is no audio
Hello
The main board of your Philips DVP should be trouble shooted. Actually this is a very skilled work, needs a sound knoledge in electronics, and expereince in repair. The fault lies on its main board itself. OK.
Oct 03, 2011 | Philips DVP642 DVD Player
My Philips DCP851 DVD player have no sound. but picture is very clear
connect to other tv to confirm that fault is in the dvd player. if still no sound then the audio processor board/main board needs replacement.
Aug 19, 2011 | Philips DCP851 Portable DVD Player
No picture
is your TV connected to a receiver or DVD player? I want to know so that I can detect if the fault is from the video cord that connects your TV to the receiver or DVD player.
Or, you can connect a DVD player to the TV and see if there will be any picture.
I hope you understand what I'm trying to say above. Your TV not having picture might be a fault from the display board/ic inside the TV or it might just be a bad wire connecting from the TV to DVD player or receiver.
So try to check the wires at the back of the TV, to be know if its a wire fault or not.
Good luck.
Jun 22, 2010 | Televison & Video
White screen when on... plays sound but screen stays white.
this problem is usually common with portable DVDs.
The fault is from the flex that connects the screen to the main board.
Fault also usually comes for screen board and the screen itself.
I would advice that you take it to a repair for checkup so that the problem would be fixed.
This problem is a common one.
I wish you the best and take care
Jan 06, 2010 | Zenith DVP615 Portable DVD Player
Portable DVD player PET719 image not available, the screen goes totally white. Sound is ok
I would advice that you take it for a checkup so that the problem would be fixed.
I wish you the best.
Jan 06, 2010 | Philips PET710 Portable DVD Player
Dvd player not starting up
Hi. In most units of this nature, you will have a stand by mode that will initiate during a major control fault that will concern the main circuit board that is housed inside your DVD players enclosure.
To confirm this control fault within the micro board, i suggest unplugging this unit for 5 minute. this is a hard reset that will drain all power and the micro board will reset itself. After the five minutes are up, simply plug back in the DVD player and power up.
If you experience the same stanby by mode and blinking code light as well after the hard reset, this will confirm the main circuit board control fault.
In this case, you will have to send to the nearest repair depot or, you can ship this device to the manufacture for a main board transplant and re-programing procedures.
Please rate and have a great day:)
Apr 22, 2009 | Wharfedale DVD-M3 DVD Player
DVD player just shuts off when using
As you say - - if it does not happen all the time, you have the worst problem ever.
AN INTERMITTENT FAULT - Horrid
You are likely to be correct, and have a loose connection / poor solder joint / dry joint within the unit.
Time and patience could find this fault - as long as you have a soldering iron, and a good avo..
Oct 10, 2007 | Panasonic DVD-LA95 Portable DVD Player
Car Audio & Video Logo
Top Takara Car Audio & Video Experts
xxxxxx xxx
Are you a Takara Car Audio and Video Expert? Answer questions, earn points and help others
