Question about Microsoft Visual Basic 6.0 for PC
Solver any problems - Microsoft Visual Basic 6.0 for PC
    Brigadier General:
  • 3,614 Answers
What exactly the problem on your VB 6.0?
Thanks
Posted on May 20, 2011
How to unscramble the word pastensify
You can use an online anagram solver or Scrabble solver for this. Just do a search for an anagram solver and several will come up.
Oct 04, 2014 | Games
On the TI83 calculator the equation solver dont workequation solver dont work
Most probable that you are not using the correct syntax.
Press MATH, then scroll down to reach the SOLVER line. Press ENTER. Create the equation, using the ALPHA keyboard to type in letter symbols.
Press ENTER. The screen that opens displays the equation and a list of the variable present in your equation. Each letter (variable) must have a value, except the unknown. If there is a 0 after the = sign on the same line as the unknown, you must clear it so as to leave a blank.
Specify the lower bound and the upper bound to speed up the search.
Once finished press [ALPHA][ENTER] to execute the (SOLVER)
Oct 20, 2011 | Texas Instruments TI-83 Plus Calculator
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
Aug 01, 2010 | Texas Instruments TI-89 Calculator
Have a multiple misfire on a 97 chevy suburban 5.7 vortec. Stumbling at idle and during stop and go traffic, idles fine in nuetral. Help?
You might consider replacing the cam sensor. The computer relys on this signal in order to generate spark timing.
Mar 14, 2010 | 1997 Chevrolet Suburban
My solver is giving me the wrong answers
I have no way of knowing why it is giving you wrong answers. If you have an idea what the answer might be, you should use this knowledge to help the calculator find your solution, either by giving a better guess (initial value) or by restricting the domain of values, instead of -1e99 and 1E99.
It is also possible that you may have set up the problem incorrectly. For this reason I am describing how to use the Solver and the solve( command.
You have two ways to solve an equation with the TI84Plus
  1. The solve( command the syntax of which is solve( expr, var,guess, {lower_limit, upper_limit}). Here expr is the expression (without =0), var is the variable you solve for, guess is you estimate of the solution, lower_limit and upper_limit are the bounds of the domain where you are looking for a solution. Of course your guess must be between theses limits.
  2. The Interactive Solver.
The solve( command
  • The solve command is accessed through the catalog of commands [2nd][0] (CATALOG).
  • Press [LN] (S) to let the cursor jump to the first command that starts with s.
  • Scroll down to reach the solve( command.
  • Select it and press [ENTER]. The command echoes on main screen.
  • Enter the different arguments: expr, var, guess, etc.
  • Close the right parenthesis and press [ENTER].
  • Wait for the solution to be displayed.
The interactive Solver
Press [MATH][0:Solver]. You see what is on the first picture (I entered K-0.5*V^2). Press [ENTER]. You see what is on the right picture.
In the interactive solver you enter a value for all the parameters, constants, for all, save the entity you are solving for, here V. So you must clear the 0 to the right of the = sign after the V. when finished you press [ALPHA][ENTER] (SOLVE).
Here is what I get for the small exemple I chose.
Left -rt=0 shows that the root was found to within the calculator's tolerance.
Hope it helps.
Thank you for using FixYa.
Dec 10, 2009 | Texas Instruments TI-84 Plus Calculator
Solver mode in equations part of calculator
Your Solver is a numerical solver not a symbolic one. You have to supply an initial guess at a solution and the Solver finds it. If you suspect, or know, that there are others jut run the solver again supplying the initial guess for each additional solution.
One easy way to locate the roots of an equation is to draw the function (without =0) and see on the graph the approximate values of x where the function vanishes. These approximate values of the roots can be used as initial guesses in the Solver.
Nov 20, 2008 | Casio FX-9750GPlus Calculator
Explain brief about Goak Seek Command, Solver, Sceanerios
Goal Seek Solver and Sceanerios are a Part of What if Data Analysis Tools.
Goal Seek find the Expected Change in terms of value to a calculated Items.
For Example if you have a sales data for the year 2007 where Profit is 350000 and you want to make it 500000 for the year 2008 so what changes you will do in Product cost or Product Price this you will find with Goal Seek. It is also known as Back calculation. It has some restrictions which is overcome by Solver. But before doing this type of calculation use Sceanerios to store different Calculated values using Goal Seek and Solver. You dont have to add these values in different sheets all the values stored as a sceanerios. so You can show different Predections to the customers without moving around the Sheets.
Nov 17, 2008 | Microsoft Computers & Internet
Solver not working properly
try a simple equation like x^2-1 which should come out with x = 1,-1
no sign change would indicate that the graph of the curve never crosses the x axis, if you graphed the above equation and calculated the zeros, it would come out with -1, 1 which it should, but if you put in x^2+1, the graph would never cross and therefore have no sign change from pos to neg or vice versa, the left-rt are the left and right bounds or the lower and upper bounds which was corrected in later calculators, Please let me know the outcome of graphing both of the above equations and then putting them in the solver. you could also use the quadratic equation to prove the answers if you liked, hope this helps
Mar 13, 2008 | Texas Instruments TI-83 Plus Calculator
Crosswords puzzle solver by Franklin
Here you go: http://66.179.52.179/franklin/data/public/manuals/cwp-206.pdf
Aug 19, 2007 | Franklin CWP-206
Microsoft Visual Basic 6.0 for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
