Question about Brother MFC-8220 Fax
Machine error What does machine error 7C mean...any help would be greatly appreciated Thanks Jk
    Scholar:
  • 159 Answers
Laser scanner error. Replace laser unit
Posted on Aug 19, 2008
More clarification as requested. I have an old model Tunturi with no model No. marked on the machine unfortunately. Problem is when start button is pushed the machine starts abruptly for about 1 second but...
Hi
clarification needs to be in your original post, not as a new post. Click COMMENT under the person you are talking to, or as a COMMENT to your own text. That way they get a notification and will help you further.
Weirdly, you have no other posts? So confusing :>)
http://www.fixya.com/users/james-wesley-parker
Andrew - Fixya Moderator
Apr 10, 2017 | Tunturi Exercise & Fitness
What does error E90 mean?
E90 =cycle blocked suggest check pump/drain etc for any blockage and if you need more on this I will post this link for you to check on these. http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q6 If this is helpful, a vote with the thumbs up would be greatly appreciated for the free advice and if you need more on thei feel free to get back to me. Thanks
Aug 22, 2011 | Zanussi WJS1265W Front Load Washer/Dryer
Error code F18 for Bosch Maxx 7 Silence washing machine
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Jun 04, 2011 | Bosch Washing Machines
F6 error! Machine stops working. Flashes F6 and beeps.
Hi!!
The F6 error means Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) • Check the Drive Motor • Check the MCU • Check the Wire Harness
Replace failed component.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
Error 7C
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
Dec 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Error 54
Dear Forceman ,
Please download the maintenance Document from this URL, for your Machine. its very helpful to you in future.
http://panasonic.co.jp/pcc/products/en/printer/model/clp/cl600/manuals/dp-cl18/MAINTE.pdf
cheeerup and enjoy life
Mar 04, 2008 | Panasonic DP-CL18 Laser Printer
Machine code question
Hi Alexandra,
I hate to be the messenger of bad news but Machine Error 7C mean Engine PCB Error. This error code is for servicer reference and may not appear on the service manual. If it does, it will tell you to unplug the unit and try again. If the problem persists, you have to bring it to an Authorized Brother Service center for repair.
The link below will take you to a Service Manual page where the error code is defined.
http://tinyurl.com/yvcv35
Best Regards,
Jan 15, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother MFC-8220 Fax Logo
183 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
