I am having trouble configuring the IP and the ssid and key. The control stops working as I try and type the key into the "Details" , "Manual, ssid, ktip, key stops working like the battery of the remote has run out?
Hi.
I can confirm this problem: When the key is entered, the unit craches (the screen goes black). A hard reset can be done, and the unit reboots after disconnecting og re-connecting the power.
When connecting the unit to the internet with a wire, the firmware can be updated via the GUI. Please note: This takes a long time. (10-15 minutes). The unit will reboot when done. Do not disconnect power og network.
When firmware is updated, the problem is solved.
Regards
Jacob Mondrup
When entering in your encryption key, use the up/down buttons to select the character you wish to use. Use the right button to get to the next character position. After all characters have been entered in your key, continue to use the right button until it will not accept any more right movements and the screen's focus is on "encryption key" or "connection."
Me too - its as though the unit has died. To get it to turn back on I have to do a hard reset by poking a pin into the reset button on the underneath of the unit. Have you figured out how to solve this ?
