Question about GPS
I have a jcpenney model 6241 am/ssb 40 channel cb radio--i need the schematic layout/and or the user manual guide--i want to confirm the power plugpins---i want the drawing for that area---thankyou for your response-- dwayneb287@gmail.com
  • 63 Answers
Http://www.worldwidedx.com
post your request there and i think you will find an answer
Posted on May 20, 2011
What channels are legal to use on a Connex 3300 with 40 upper, lower and regular settings?
only the CB band to TX on.. you may RX on any frequency.
ch.1-ch.40 am and SSB if it had it.. are the FCC allowed channels. yes there are people on those other bands. user beware.
Feb 08, 2014 | Connex 3300 240-Channels Base CB Radio
Adjust modulation pot cb
4 watts on am and 12 on ssb the modulation pot isn't going to help you . go to www.cbtricks.com and get the service manual.
Jul 27, 2013 | Galaxy Radios DX-979 40-Channels Base CB...
Power drops on galaxy dx 959 when switched from ssb to am and back
if you mean that the power drops from ssb to am then when you change it back what you should do is check to see what power you have to begin with.you may have to go inside the radio to adjust the power. there is hi power and Low power so watch yourself.
Mar 28, 2013 | Galaxy Radios DX-979 40-Channels Base CB...
Purchased a midland 75 785 from u s will it work on u k channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-822 40-Channels Handheld CB...
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Need to kwon the numbers for the galaxy santurn base radio to repair it cause the one it has dont belong to it.
What are you needing can you explain more detail. And all the exports base radios are the same schematic as. Are the mobiles. The galaxy 33 and gal 99 are the same radio just the 33 doesn't have the ssb parts
Mar 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
Mar 25, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
May 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Need a schematic diagram on a uniden grant lt
http://www.cbtricks.com/radios/uniden/grant/graphics/grant_sch.pdf
Jan 29, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
GPS Logo
379 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
