Question about Garmin nuvi 250W GPS Receiver
When i connect it to my car it displays a message which is a picture of the garmin plugged into the computer. It appears as if it wants me to plug it into the computer when i did this it still appeared
Doubloh7, are you using a bonafide Garmin car adapter? Unofficial adapters can cause this to happen. If you are using an unofficial adapter, it may be time to invest in one from Garmin.
Hope this helps..
Posted on Jun 09, 2011
Garmin 1300 freezes when usb cable is plugged in to the computer. It only shows the word GARMIN and the little picture of the gps plugged into computer.
This is normal. The satnav is meant to freeze when connected to your computer. This is because when it's connected to the computer it's usually for updating information on the satnav and that wouldn't be possible if the satnav was active.
Mar 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
My Garmin Nuvi 270 will not work when charging on the computer or in the car. It just shows the computer connection picture. Once I unplug it, it functions normally. I would like to have it plugged into...
It's normal for it not to work when plugged into the computer. It's not meant to work so changes can be made to it's software or maps, like updates, through the computer. These would not be possible if the satnav was operating.
When it's plugged into the car charger it should work. The problem is caused by wear on the mini USB socket on the back of the satnav. It appears that the mini USB plug is pushed in fully when it's not. Push it in further and the problem will be solved.
Oct 17, 2010 | Garmin NUVI 270 GPS Receiver
My Garmin won't do anything. Has a picture at the bottom with what appears to be the Garmin - USB cord - computer. Any clue? I do have it plugged into the computer right now to see if it would do anything...
The problem with the car charger is in the mini USB socket in the back of the satnav. The mini USB plug doesn't go in far enough although it appears to be fully in. Push it in further and it will work. When it's connected to the computer it's not possible to use the satnav. It's meant to show this picture then.
Oct 16, 2010 | Garmin Nuvi 265W GPS Receiver
Product nuvi 200w/ powering up the device, all that is displayed is a small picture of a gps connected to a pc via usb cord. Have the update card for last year. A message displayed recently that map was...
The reason that the picture of the gps connected to a pc is shown is because the mini usb plug is not pushed in fully into the back of the satnav. This is a common problem with the 200w as it feels like the plug is fully in when it's not.
When the map is on the satnav for a year it displays the message that it's out of date. It can be updated again at www.garmin.com but if it was updated last year it may not be worth the cost of updating it again as there will be few changes. Generally I update mine every 2 years.
Aug 04, 2010 | Garmin North America GPS Map Update Maps...
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
I have just purchased a sendai universal home charger, when I plug it is my Garmin 200, and the other end into the electrical socket I get a picture on the screen, looks like a computer with a plug running...
The nuvi thinks you've connected it to the USB port of your home computer. It's charging, so pay no attention to the screen.
If you HAD connected it to the USB port, you would also see the nuvi as a storage device attached to your computer. That's how you can download pictures that you can display on your nuvi. It's also the mechanism used when you update your maps and/or software.
Apr 16, 2010 | Garmin nuvi 200W GPS Receiver
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
