Question about Intel Pentium D 915, 2.8 GHz (BX80553915) Boxed Processor
Sir, i have got intel pentium 2.8 and board asus p5kpl-cm and my cpu temp show 86 and fan speed near 2500.plz give me a solution for high temp. thanx.
    Sergeant:
  • 187 Answers
Check if the cpu heatsinkl fan if fully tight. And try to apply the white paste( will be available in stores) on the cpu then seat the heatsink and tight it firmly
PLS REPLY OR COMMENT. THANKS
Posted on May 20, 2011
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I have ASUS intel G31 chipset (P5KPL-AM/PS) motherboard.Now I am not getting any display although RAM is working condition.will you help me?
this mainboard is intened for use with XP or Vista only OS and Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron Processors
Compatible with Intel® 05B/05A/06 processors ONLY
go to this site to download video drivers
http://driverwhiz.com/drivers-en?brand=Intel%20Graphics&logo=Intel&subid=1002-ca-en-90000000421&gclid=CJWIgquX1KQCFcu7KgodfGqqJw
if the computer powers on w/o video , it could be heat issue with the CPU, --turn off the computer, remove battery and rear case - remove the heatsink fan and apply new thermal paste on the CPU- then put heatsink fan back , battery -- and turn on computer --if the issue persists, its bad onboard video card
Oct 15, 2010 | ASUS Maximus II Formula Motherboard
What Cpu fit a p5kpl-c and the best to buy.
This is older type of motherboard, made by Asus and supporting Intel Pentium 4, 775pin processor (LGA775). It will support DDR2 to the value of 4GB, it will support 64bit operating system. it have single PATA port, SATA is present but no RAID configuration.
This motherboard requires PCI video card, there is noAGP port and no build in graphics. System is based on Intel G31 Express chipset.
Theoreticaly this motherboard should accept all Intel Pentium for 775 pin processors, albeit early production may need BIOS flush with latest BIOS.
List of processors accepted:
Intel Pentium 4, Intel Pentium D, Intel Pentium Core 2 Duo, Intel Pentium Core 2 Extreme and Intel Pentium Core 2 Quad.
If you need more information or drivers for this particular board, please visit this site adn select exact model:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Do not hesitate to leave feedback how did you go with this advice :-)
Aug 17, 2010 | Computers & Internet
P5kpl-cm with intel pentium e6300 reboot cycle !!!
first refresh ram & clean ram slot, then check cpu fan properly working or not, if you do this then your machine working fine.
Mar 16, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Drivers Pack For Windows Vista 7 is required
I will give you a alternate and easy way for your problem.Just download this software named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 17, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Intel Pentium  D 915, 2.8 GHz (BX80553915) Boxed Processor Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
