Question about Whirlpool Dishwashers
ADP4650 dishwasher completes drain cycle but will not commence wash.start lamp flashes 7 times.
Turned off appliance,unplugged and left for 2 hours after which it worked fine.thanks.
Posted on Aug 16, 2008
LST216A - From start of all wash progs. - After about a minute (when it sounds as if pumping/draining) first 3 indicators + green on/off lamp start flashing ?. Water inlet seems o.k. !
Because of when it happens I would hazard a guess that it hasn't completed it's draining cycle. Check the outlet hose is not blocked, watch when it drains to see if there is a good flow. If you can hear the pump and it sounds normal I would look at the outlet hose first.
Jul 30, 2014 | Hotpoint Dishwashers
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
