Question about Kodak EasyShare Z612 Digital Camera
It says the memory card needs formatting but when i go to format it this error occurs, FILESYS ERROR e00100
  • 11 more comments
  • Anonymous Aug 16, 2008
    exactly the same problem. wont format teh memory card and same error message appears
  • becksandgem Aug 24, 2008
    When I try to format the memory card, it says formatting filesys error
  • turnip180 Aug 27, 2008
    when formatting it says filesys error
  • Anonymous Aug 28, 2008
    Same problem with C310 camera. SD Card reads and formats fine in a computer but gets the needs to be formatted and then this same error from the camera. Its a 2GB card which worked fine until we offloaded the pictures when it was full.
  • mwhelan8345 Oct 19, 2008
    when putting my camera on it says memory card needs formatting when trying to format it is saying FILESYS Error e00100 any soloutions
  • creamteaquee Dec 11, 2008
    same problem!!!!!!!!!!!!!!!!! what's going on?
  • somarv1996 Dec 13, 2008
    did anyone figure this out yet? im having the same problem.
  • Anonymous Dec 15, 2008
    yes i have the same problem..
  • Anonymous Dec 27, 2008
    i have the same prob with mine. i dont know what it is. :-/
    I have the same problem what a load of rubbish this camera is
  • chornoi Jan 14, 2009
    Memory card won't format - have tried a variety of different ones
  • deaddog1 Jan 18, 2009
    I am unable to format any memory cards. I have tried the same cards in my daughters camera and they all work fine.
  • blueeyesbody Jan 25, 2009
    ihave the same problem i got a 4gb and itsaid to format it did not work so i got a 1 gb and it still wont work
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
Posted on Jan 16, 2009
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Cannot format sandisc 2GB memory card in my Kodak easyshare CW330 camera. it says filesys error e00100
Use a card reader and format on a PC. When card is inserted go to my computer and the disc should be there, right click and go to format then proceed as per screen instruction.
Dec 29, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Trying to format screen says filesys error e00100 how do you fix this
if you already try to fromat the memory card into the camera and there's an error come.try to format your memory card from your computer if you have card reader.if the problem still occur you memory card have a problem and you need to buy new one.
thank you
Jul 08, 2010 | Kodak EasyShare C310 Digital Camera
FORMAT MEMORY CARD
After downloading any pics from the card using a card reader if necessary, go ahead and format it in the camera.
Jun 21, 2010 | Kodak EasyShare C315 Digital Camera
Kodak camera 2 gb memory card will not work
Format it in a PC using a card reader. Then use in the camera.
Aug 10, 2009 | Cameras
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    I Cant format my memory card
    use a memory card reader and connect it into your PC, let the your memory card plug into your reader and format it into your pc using that;
    Nov 23, 2008 | PNY 2GB microSD Memory Card
    FILESYS ERROR e00100 2.0GB PNY technologies
    try formating
    u get warranty on this and hence approach the point of sales
    Jul 01, 2008 | PNY 2GB microSD Memory Card
    Kodak EasyShare Z612 Digital Camera Logo
    413 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
