I had my cannon carlton gas fire serviced today. the technician did not know very much and took him an hour to put it back together. PROBLEM: the fluffy white strip did not stick back where it was so it was not put back. one screw over which he said he then put it back, the glass was technically cleaned but still dirty. is there anyone out there who knows how to service this type of gas heater
techman
  • 3130 Answers
SOURCE: ac turning on and off
How did they check the freon in the home? You can feel the front(evaporator coil)coil on all four sides. Are you sure the motor is running fast enough? If the four corners do not feel cold in about 5 minutes or so, there is a compressor problem, Capillary tube blockage, moisture in the system or you are low of freon. Good Luck
Posted on Jun 15, 2007
SparkGap
  • 363 Answers
SOURCE: WD-52327 Lamp hour indicator.
Found this in another forum. So apologies if there are any innacuracies. service code
menu-5-7-5-7
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
menu-5-7-7-0
Posted on Nov 07, 2007
peepnklown
  • 175 Answers
SOURCE: Canon IP2000 Service Manual
You can buy the Service Manual/Schematics from this site: http://www.smpcshop.com/PIXMA-iP2000-p-353.html
Posted on Nov 10, 2007
SOURCE: Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Posted on Jan 13, 2008
SOURCE: I only need natural gas
Vote for a democrat
Posted on Apr 25, 2008
Put on new gas valve fires up but goes back out
Hello Mitch;
My name is Peter. I am a retired field service appliance technician.
Why did you put in a gas valve. That is the least likely component to fail.
1.) Restricted Air flow - If your unit is plugged up with lint it will shut down.
2.) If you have a blown thermal fuse $10.00, it will shut down.
3.) If you have a bad high temperature limit switch $12.00 you will shut down.
4.) If your igniter glows, it still may be wearing down and does not have enough power to open the gas valve.
Send me your model number and lets fix this together.
Peter 414-306-1362
Glen Burnie, MD
Dec 11, 2014 | Dryers
2004 nissan quest will shift into all gears and can feel the tranny shift into those gears but has no response to gas pedal except in park, and neutral. If you apply break it will cut the navigation...
sounds like you have a serious PCM or ECM problem..contact a dealership with a reputable service department and ibquire about re flashing your cars computer
Dec 10, 2013 | Cars & Trucks
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
I have a 1985 Honda VT500 Shadow. It bogs down at about 5500 rpm. I changed the 4 spark plugs, checked the air filter, took off the carbs and blew out the bowls, looked clean. Put back together and
there are many air channels in the carbs, witch can be dirty, clean them with very thin wire, and first bled out the gas, check the 2 diaphragms in the carbs
May 20, 2012 | 1985 Honda VT 500 C Shadow
Carrier weathermaker sx (model 58sx040-cc power vent motor and gas velve cylanoid are kicking in and out, do you know what i can do to fix this problem ??
I believe this is the furnace with a spark to light the pilot light. If so the best advice I can give is to replace the whole pilot assembly. There is a very old style flame sensor in there that is not serviceable. This has driven many a technician around the bend.
**NOTE: It is a real pain to get out, and back in. You need to take off the fire box cover and the panel underneath it to get it out. You also need to take the pilot tube off the gas valve. This may be something that you want to call a service tech for. It could be a little tricky and because you are dealing with gas, you want to make sure that it is put together correctly and safely.
Nov 08, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cannon Caress gas fire manual
yes go to ths link, took me ages to find but when i put in hte serial number it can straight up, but can you tell me where to buy the replacement coals? heres your link:
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/190.pdf
Oct 28, 2009 | Cannon Kitchen Ranges
Cannon ip 1800 printer
hi, your paper feeder might be jammed, try seeing if your little wheels turn properly (where the paper is fed) let me know..
Sep 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
