How do i replace and install a new 2/25f sh. capacitor for my carrier model wcarf010ee
  • 63 Answers
Most likely it is in the back of the unit which will require you to remove it from the wall or window and disassemble the cover and remove the top. if it is in the control box then you may be able to do it without taking it out of the wall. always remember to unplug it first!!! all window and wall type units are very tightly packed and not very repair man friendly. take the cover of and remove the box that hold the controls.
Posted on May 20, 2011
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
I have a Carrier AC model 38TKB030300 and I want to confirm the correct capacitor so I can replace it. Can you help? My central home unit shut off and the repairman said it was the capacitor that was...
Look at the old capacitor. The mircofarad rating should be printed on the side. If you can't read it then take the capacitor or the model # with you to a heating and air dealer the sells Carrier products. The repairman should have put one it for you.
Sep 01, 2010 | Carrier 38CKC060 Air Conditioner
The condenser fan for carrier xarios 300 is not
there is a run capacitor is probably bad.
you can purchase a replacement one from slakey brothers. However the capacitor will still have a charge after the power and wires are removed. after turning off the breaker use a long bladed screw driver and ground the electrical leads to discharge the capacitor before removing. take it with you to the supply house along with the model and serial number of the condensing unit.
Apr 15, 2010 | Carrier Heating & Cooling
Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
sounds like a bad capacitor usually screwed to the blower housing (round or oval shiny can)
this gives the motor a kick start)
depending on the motor there is usally two brown wires that go to it
check the mfd rating on it probably 5mfd and replace it with a matching one
its a very inexpensive part
Aug 02, 2009 | Carrier 38CKC036 Air Conditioner
Buzzing in TV is from part sdt sh 112dm. will changing the part quiet the buzz?
C622 is the real problem. It is a 470 uf capacitor filtering the power to the blue relay. Radio Shack sells it for $1.29 part number 272-1030. make sure you observe polarity when you replace it. In other words, the side marked minus goes on the negative side. Check the markings on the old capacitor and replace it the same way with new one. The new capacitor has a higher voltage rating which is even better.
Jun 29, 2009 | Sanyo DS25390 TV
How to wire new motor & capacitor
Do not panic. The new motor has several ways to connect common. READ MORE
If this is a fan for inside then you have the speeds to contend with. The info on the READ MORE link is for that of a central unit but it covers your question too. As far as the shaft being too long you have to cut that yourself. I have an electric hacksaw that cost $500 bucks from milwaukee tools that does a fair job of that.
May 16, 2009 | Carrier 52CQ315 Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
