Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Error Code SC 120
HELP.
Can you help me with this error code on the Ricoh Aficio 1515MF? Here is what has already been done and the problems continues..
A SC120 CODE ON YOUR RICOH COPIER.THAT CODE IS A SCANNER HOME POSITION ERROR.THE SCANNER IS A LIGHT ASSEMBLY THAT TRAVELS BACK & FORTH JUST BELOW THE GLASS YOU PLACE YOUR ORIGINALS ON SCANNING THE ORIGINAL. IT SOUNDS LIKE IT MAY HAVE BOUNCED OFF ITS TRACK WHEN IT WAS BEING MOVED.IN YOUR E-MAIL YOU SAID YOU TURNED IT OFF & ON TO RESET THE CODE, WHICH IS THE PROPER PROCEDURE.THIS MACHINE SHOULD HAVE 2 ON SWITCHES. ONE ON THE UPPER RIGHT WHICH ONLY TURNS THE LIGHTS OFF TO THE CONTROL PANEL.ON THE LOWER LEFT SIDE THERE SHOULD BE A RED SWITCH THAT IS THE MAIN POWER SWITCH.THE RED SWITCH IS THE ONE THAT RESETS CODES.
You need a tech...here is the description of your "SC":
The scanner home position sensor
does not detect the scanner leaving
the home position.
Here are the possible solutions:
- Defective scanner home
position sensor
- Defective scanner drive motor
position sensor connector
connector
- Defective BICU board
Posted on Mar 12, 2009
SOURCE: error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Posted on Mar 23, 2009
  • 232 Answers
SOURCE: necesito los drivers para la impresora Ricoh Aficio 1515MF
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x15_15f/x15_15fen.htm
Posted on Mar 05, 2010
SOURCE: service call sc:543 for Ricoh Aficio 1515mf
Phone number was programmed by whoever sold the machine in the first place...call whoever you like.
The error relates to a fuser (or warm up ) error. It could be blown fuse, lamp, thermistor, etc. It can only be reset in service mode by a technician, after the problem is solved.
Posted on Mar 25, 2009
SOURCE: Ricoh Aficio 1515mf SC 121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Posted on Apr 30, 2009
newport74
  • 58 Answers
SOURCE: HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
Posted on Feb 27, 2010
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
Aficio 270, Sc 392, error code
Good morning,
I need help, my Ricoh Aficio 1022 with this error SC-392 is an error of sensor density toner.
I've only had the unit for another and still the same, and the unit is running on another machine.
Already cleaned the connectors Unit
Please if someone can help me.
E-mail: cybercopy.udi @ hotmail.com
Jul 16, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP 1600 Le error code sc 322 occured during print job how do i clear it
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Jan 12, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Apr 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 1515
Turning the main power switch off and on, resets the SC code if the error is caused by incorrect sensor detection.
If the error is still there, the laser synchronising detector or laser diode is faulty. Please call a service engineer.
Good luck and please rate me, thanks.
Jan 13, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Mar 07, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
6,110 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
