Question about Microwave Ovens
I have a moulinex microwave and the spring on the door latch mechanism is broken and not shure where it goes back?and the plastic cover on the door(window) is broken needs replacing. all that is written is model:depose FM2935 series:FM2 24litres 220 volts system
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave door button spring broken and door wont open
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave door hook broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Dec 02, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken door latch on Model 63679 Kenmore Elite Microwave.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
Posted on Jan 18, 2009
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
The door of the microwave is not opened correctly
It's hard to say what could be wrong, You did not provide the Make or Model of your Microwave. Generally the latching mechanism is mechanical in nature. The latch if made of plastic could have broken, there could be a spring or a lever out of place. the movement could just have some food that got in there and "gummed up" the works.
The only way to truly figure out what the problem is is to pull the cover off and inspect it.
Dec 29, 2014 | Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
Panosonic NN-S525BF Latch Spring Broken
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Jan 24, 2009 | Panasonic NN-S254BF Microwave Oven
Door latches will not close onmy Panasonic Dimensions 4 Microwave NNCT766MBPQ.They appear loose as if a spring has broken.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Panasonic Microwave Ovens
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
