Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
I can not get the water, normal heavy traffic selector reinstalled after taking unit apart, i replaced the pump, and now i cannot get it back together, there seems to be a special way it goes together, and i'm not finding it. Are there any videos, or pictures that show how it should go back together?
heatman101
  • 43501 Answers
SOURCE: i need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell steam cleaner model 9300 not putting out soap
heatman101
,b..,
  • 273 Answers
SOURCE: im trying to put the peice back together that goes
I tried to find a service manual for this, but came up with only a exploded view diagram:
http://ineedbags.com/images/b8920.jpg
There are several YouTube videos covering the 8920:
http://www.youtube.com/watch?v=SLyDeM10k9k&feature=related
Here is the Bissel User Guide for the 8920:
http://www.bissell.com/downloadfile.aspx?id=645
Lastly,
http://www.bissell.com/customer-support/
Good luck.
Posted on Feb 28, 2011
BissellCSR
  • 276 Answers
SOURCE: need to replace power cord for bissell model 6585
A BISSELL Authorized Service Center should be able to help you out. You can find one nearest to you and call them first if you want:
http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Posted on Apr 05, 2012
My formula tank is not emptying on my 8910 proheat eurka cleaner
Make sure it is on heavy traffic on the selector set. You may find it is on Clear water rinse. FYI you will find your machine will clean better and your carpet will be cleaner if you use a weed sprayer and mix your soapin it. Just spray it down fairly heavy and let it set for 10 minutes. Then just use straight water in both tanks and you will be amazed. It is like a lasagna dish if it soaks for a while it comes cleaner easier.
May 13, 2014 | Bissell 8910 ProHeat Clear View Upright...
What is the amount of bissell cleaner to use in the pro heat machine do you have tomix with water
The ProHeat units all have a self setting system for mixing. there is a swith you select for "heavy traffic..Normal...or Water rinse" that determines how to mix itself.
here is site to get user guide for your model.
http://www.bissell.com/searchresults_userguides.aspx?searchType=find+a+user+guide&searchtext=proheat&mode=228
Hope this helps
Thanks
Please rate FIXYA
Jun 03, 2011 | Bissell Vacuums
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
It isnt puting any liquid down
Apr 24, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Water wont come out
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
It won't dispense water or suction it up
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
Apr 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9500 ProHeat 2X Clean Shot will not let water put from tank?
Apr 19, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
When I am cleaning carpet, the water spray works
Apr 19, 2010 | Bissell 25A3 Upright Vacuum
Using too much solution AND leaving dirty streaks in my carpet
The reason for it to use soloution is it may be set on heavy traffic. To fix this turn your knob labeled heavy,normal& light traffic and water rinse to either normal or light traffic. To fix the streaks when you pull the machine backward pull it super slow (you may have to do this a few times) if this dont work take it back
Jul 31, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
186 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
