Question about Hoover Refrigerators
Hoover HCA 404 err01 what has - Hoover Refrigerators
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
May 29, 2012 | Hoover HCA390FFK Bottom Freezer...
Where can I get an ECHO HCA-2500 operator manual from?
Go to echousa.com. There you look under support and you can download a operator's manual. I went there and they did not show a hca-2500 but showed a hca-2400, it may be the same.
Good Day.
Oct 08, 2009 | Echo Garden
FRIDGE COMPARTMENT NOT COLD ENOUGH.
If you have never defrosted it before, leave it off for a lot lot longer, doors open in a warm area. Is the fan working when you close the door ?(or hold the door switch in), if not, there could be a problem with the condenser fan), otherwise 90% of the time, they are frosted up internally, and because of good insulation, need time to "warm up" inside, in order to defrost
Mar 30, 2009 | Freezers
Water Filter Not working
Hi Nicky,
We just had the same problem; and we've solved it.
Press the MENU button (4 times) until the Pure Water LED is flashing; then press and hold the SET button down until the screen goes back to the main menu.
SORTED!
Catherine & Matthew
Jan 02, 2009 | Hoover HCA390FFK Bottom Freezer...
Hoover fridge freezer HCA 455 FKPW. Does this cotain R12 gas and can it be repaired if there is a leak?
gas type is on rating label and is probably r600a (butane)
whether it can be repaired if there is a leak, depends quite simply, where the leak is.
what makes you think there is a leak??
Aug 21, 2008 | Hoover Refrigerators
Refrigerators Logo
99 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
