In canon printer mx 330 ink catridge cannot recognized u051
  • 17,130 Answers
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Posted on May 20, 2011
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
CANON PIXMA MX 328 EROR U051
Ink cartridge not installed, or not properly installed. Install the ink cartridge properly. If the error is not cleared, the ink cartridge may be defective. Replace the ink cartridge.
Aug 07, 2011 | Office Equipment & Supplies
Hi, I am using a PIXMA MX 310 and have replaced the cartridges. It says Check Ink U051 BLK COL. I have tried holding the STOP/RESET button but this has not worked (it has worked in the past). It won't...
Hello Maggie
You need to replace the cartridge with a new one original canon,not refill.If you refill the cartridge the printer not recognize it.If i have been useful pls give me a vote :)
Mar 06, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
Ca i recharge catridge form cnon pixma MX 330?, i
All catridges are made to show the ink levels only for 1st use, once you refill the cartridge you need to reset the ink level chip, some cartrides level cannot be reset, some can be re-set.
There are solution available for some specific printer ink cartridges on how to re-set the ink level.
You can google and loacte the solution giving cartridge number in the search field of google.
Dec 07, 2009 | Canon PIXMA MX310 All-In-One Printer
U051
Try taking it out and cleaning the electricial contaccts with a pencil eracer.
Dec 28, 2008 | Canon Pixma MP450 All-In-One InkJet...
I have a Pixma MP830 all in one inkjet printer. After I used Catridge World ink tanks, printer would not work. I have since refitted Canon ink tanks, but unit says, "the following ink tanks cannot be...
did buying Canon cartridges rectify the U051 problem? do not want to pay out for more new cartridges (bought last ones from Cartridge world!) and not fix the problem. thanks
May 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon mx 300
i have canon mx300 printer.I refill second time color cartrige and when I push him back apears this mesage " CHECK INK" cod U051. I tried to reset mai Canon like alfr3do and the same mesage. You could help me?
Thank you!
Apr 12, 2008 | Canon Office Equipment & Supplies
278 people viewed this question
jasbo
jasbo
