Question about Epson DLQ 3500 Matrix Printer
I have epson DLQ 3500 printer which some times accept paper from mannual tray but frequantly it eject paper after loading pls guide med to solve this problem. its working fine with tractor
  • 38 Answers
SOURCE: Paper Out Sensor Not Working
its only problem with paper sensor .
adjust the sensor arm , which can get touch the paper guide which cause the same problem
its a mechanical sensor and it can be removed , clean and adjusted if contact problem of sensor arm
Posted on Jul 29, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
aicaxz
  • 511 Answers
SOURCE: Epson Stylus Photo R200 will not accept DVD tray
Have you select the media in printer setup?
Posted on Jun 14, 2009
xptareq2000
  • 1447 Answers
SOURCE: Printing stops halfway through on Epson LQ300+
you use dpi 180X180 then print full page and speed fast
Posted on Jun 25, 2009
vanherringto
  • 1738 Answers
SOURCE: where do we find 64 bit driver for dlq 3500.
A 64-bit driver is not available for your Epson DLQ 3500 printer and none is expected to be released.
The only driver available for the EPSON DLQ-3500 is for Windows 95/98/ME/2000/NT4.0
Posted on Feb 05, 2010
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
How to set ip address for epson dot matrix printers
How to remove the ip address,for dot matrix printer?
Feb 06, 2012 | Epson DLQ 3500 Matrix Printer
Printer EPSON DLQ 3500 prints only at right side of the page in 3" area, not prints on whole page.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed.
Sometimes it is possible that the head is not reacting to the need of the PC command
May 06, 2011 | Epson DLQ 3500 Matrix Printer
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson DLQ 3500 Matrix Printer Logo
168 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
