Question about Vizio L32 32 in. LCD HDTV
Hello, my name is Charlie.The sound on my 32" Vizio keeps cutting out. Usually I turn the station and it comes back, today I had to turn it off and turn it back on for the sound to come back. I'm concerned because I just bought the tv. Is there anything I can do to fix this or should I take it back?
  • 916 Answers
Since it is new and under warranty you should return it.
Posted on May 20, 2011
No Picture-No Sound Just Vizio
Same on all the video/audio rear inputs?
If so set may require a firmware update--talk to Vizio.
Jun 17, 2012 | Vizio L32 32 in. LCD HDTV
I have the Vizio vp322 hdtv10a that doesn't turn on,I opened the back panel and found that the capacitors aren't bulging.
Hello, might need a Main Unit or Power Supply by the sounds of it. Try out a company named ShopJimmy.com for parts. I have used them with great success in the past. I included a link to their site from your model page. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=vp322
Sep 06, 2011 | Vizio L32 32 in. LCD HDTV
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
When I hit the power button on my 32" Vizio Plasma
You have a TV with a failing power supply board. There are parts in the power supply called capacitors that start failing and this causes the power supply to not be able to properly filter the voltages. When you keep turning it on and off the capacitors will finally hold a charge correctly so the voltages will stabilize and the TV turns on ok until the next time you turn it off. As time goes by the capacitors will degrade more until the TV will not work any more. If you can solder then you should be able to repair the TV yourself. We have a page on our web site http://www.ccl-la.com/blog/index.php/capacitors/
That explains what capacitors are and how to determine the bad ones that have failed. If you replace the failed capacitors in the power supply then you should have a working TV again.
BuddyMc
Corporate Computer
Dec 15, 2010 | Vizio VP322 32 in. Plasma TV
I have a 32' Vizio, colors are mixed up
This *could* be a result of the cables that connect the circuit board to the LCD loosening. These are held in place with a special process, and the average home repairer will not have the materials need to repair it. Call Vizio support and talk to them about it. They have been quite helpful to me. Just remember, you will be talking to a human, and nobody appreciates being cut down. Be polite and ask your questions nicely.
They may be able to work with a local repair shop to get it fixed.
I know the process used to attach the flex cables, but I cannot repair them myself.
Joe
Dec 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32'' sound off after a few hours on hdmi 1
had same problem, main board issue if sill under warranty they will come out to your house and fix it for free
Nov 19, 2008 | Vizio P4221 Television
Digital channels freeze
I also had this channel 5-1 freezing problem and spoke with Vizio support a few times. They thought the problem was the SSID code from the local CBS station and said they would try talking with them. I am not certain if they did this or not, but, as of mid December, my Vizio no longer has this problem.
May 06, 2008 | Vizio GV42L 42 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
394 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
