The picture mode on my tv is stuck to wide. When I try accessing this feature through the remote's "p-mode" or "p-size" buttons it gives me an message on the screen that says "not available." I've also tried accessing this feature through the menu on the remote and on the side of the tv but I still keep getting this same error message. I tried reading through the manuel, but there is nothing under the troubleshooting area that helps or addresses this issue. Is there a way to reset the tv to its original factory settings? Please help!
  • 3 more comments
  • gomezadan May 20, 2011
    Thanks, I appreciate your assistance. My cable box is a Scientific Atlanta "Explorer 8240HDC."
  • gomezadan May 21, 2011
    Hey bro, I got it. I played around with the cable box as you had mentioned and got it to start working again. Thanks again for your help, I appreciate it. Take care and say hello to all of the pretty girls for me back in India. Take care.
    This tech was accurate and helped me get my television back in order. Great job and thanks again!
    This tech was accurate and helped me get my television back in order. Thanks again, it is very much appreciated.
  • 4,889 Answers
If it says "not available" then you have to try the settings of the input source such as a cable box or something. Chnage the aspect ratio to 16:9 . If you can get me the model number of the box I will see if I can get your precise instructions.
Posted on May 20, 2011
  • eagle338
    eagle338 May 20, 2011
    Ok got it. I am about to log off though as its 3Am in the morning here. I will get back to you first thing in the morning
  • eagle338
    eagle338 May 21, 2011
    Glad to hear that amigo. Thanks for using Fixya!
How do we get shows (programs) to cover the whole screen on our tv
You can access either through the TV's remote, or the cable box remote picture settings for choosing picture size (i.e., normal, wide, stretch, wide zoom, etc.).
Oct 20, 2014 | Televison & Video
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
Can't restore "normal" screen. It is stuck in
You might try pulling the AC plug overnight; this could be a simple 'lock-up' of a single circuit and removing its supply voltage may cure it.If this doesn't work, take any digital camera, turn it on and watch the viewfinder (LCD), aim the remote at the camera's lens and press the mode select button. If it is functioning as it should, you should be able to see a white flash occur when the remote's button(s) are pushed. The sensor in cameras is capable of 'seeing' infrared but displays it as a white light.
If the button is dead and you feel adventurous, pop open the remote's case, gain access to the board with the fixed switch contacts and gently clean them with a cotton swab dampened with rubbing alcohol.Also clean the little carbon buttons attached to the remote's keypad, again gently.
Reassemble and try it again.
If the failure is still there, then a circuit (unfortunately probably on the main board if all other functions are working) has failed and the replacement of the main board is fairly pricey.
Oct 01, 2011 | Vizio E370VL 37 in. LCD HDTV
I have a Dynex TV thats about two years old. Model DX-L150A11 It does not repeat the picture size when channels are switched. I have to use the zoom feature to get the correct size picture. I tried all...
Do one thing Go to the menu of the tv. Select Picture setting and then select Advanced video and select Zoom mode. In zoom mode select Wide. If you hve already done this ,
Then select the Overscan option in the same menu page and select it as ON .
Next one select Auto zoom in the same menu page and select it as OFF.
OK
Sep 04, 2011 | Televison & Video
I too have the problem where the top and bottom of the picture is cut off on the TV screen. No formatting of any kind fixes it. What is the answer?
Some of the wide screen programs will leave blank strips top and bottom of the screen, you can fill the screen if your TV or the remote has picture size buttons where you can select "movie" mode or "movie zoom" modes. try stepping through picture size buttons. Some times it is marked as "wide" on your remote.
Jan 03, 2010 | Envision L32W761 32 in. LCD TV
TV is stuck in expanded picture mode & won't return to normal
seems to me as a Sony TV. The sony tv has this feature ready in the menu. you can do zoom out ,standard etc,
But the real problem comes when the tv is turn off and then you get back to turn on the tv (lets say next day)and you find the same big heads.
what you have to do is going to the menu same thing but this time look for an option is called picture size default. This option make learn the memory what size you want custom when tv is turn on.This function is in the same page as the picture size page (refer to the user's manual) but has to be the default mode where you want the change.
The problem with sizes now days is some shows fit perfect some others not. and besides that the cable box has those features too(change size of the screen)
What i do in this sony tv to start first is keeping it in the standard size in the tv menu and i defaulted too.
when some size adjustment is needed i do it in the cable box remote control .Once again this example i do it in SONY tv, Maybe you have to post the problem again if the tv is different brand.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
In the mode where i choose either wide or
The feature you're trying to use is grayed out when it's not available. Check your remote for a "zoom" or "picture size" button. Press the button a few times and you should find a setting which brings the whole picture back onto the screen. It sounds like you are zoomed in too far right now, so captions at the bottom are being cut off.
Mar 19, 2009 | Vizio L32 32 in. LCD HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
The writing on the screen is stretched beyond the width of the screen and I lose script on either side - I have checked the fine tuner on the remote but it doesn't seem to have the ability to fix the...
if you have a wide flatscreen tv it could be that the picture size is in the wrong mode. under the mode button on your tv remote should be two buttons labeled wide and zoom. try pushing these buttons to adjust the tv screen size.
May 02, 2008 | Televison & Video
Size of the picture decreased
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Jan 23, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
Top Televison & Video Experts
