Question about Vicks V3100 1.2 Gallon Humidifier
Making gurgling sounds and spitting water. Do i just need to send it back, it's only a few months old
    Genius:
  • 1,015 Answers
Before I returned it I would clean it thourghly and refill with clean water and about 1/4 teaspoon of table salt. Run it thru a full cycle and see if that helps. You can also rinse it out and refill with a 1/2 cup of vinagar and run again.This shoul help loosen and clean any mineral deposits. Hope this helps. Thank you.
Posted on May 20, 2011
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
NOISY FAN ON HUMIDIFIER HUNTER 34356
Try using WD-40 or sewing machine oil on the bit that the blades are independent from the motor usually just a small opening that you can try to spray some lubricant in there which will reduce friction and noise by lubing up the bearing and decreasing wear if that helps you will then know what the underlying issues are and if you need further action
Sep 24, 2017 | Hunter Humidifiers
My humidifier is spitting water plus steam. Kind of weird. Didnt do before. Level of water is ok, added 1 flat tablespoon of sea salt and 2 tabkespoons of vick oil. What's happening?
More than likely, mineral scale has built up inside the tank and the mist tubing.
To clean it, turn the unit OFF & unplug it. Empty any remaining solution that's in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Plug the unit in and turn it ON. Allow it to run for 5 minutes, then turn unit OFF and allow it to soak for 30 minutes to and hour.
Then turn the unit back ON. If the water spitting has stopped, run the unit unit is half empty. Turn it OFF, unplug it and empty any of the remaining solution. Refill with Bottled Distilled Water and run it until it's empty. Doing so, will flush out any of the remaining solution and scale.
In the future, it is best to use Bottled Distilled Water, rather than tap water. As the Distilled Water does not contain any harmful minerals or chemicals.
Hope this helped you and thanks for choosing FixYa.
Sep 15, 2011 | Vicks V150SG 1 Gallon Humidifier
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The humidifier spits hot water out and sounds like
Try soaking the heating unit in lime away or vinegar to remove lime deposits, if that doesn't help add a small amount of salt to the water.
Oct 31, 2009 | Vicks V150 Humidifier
Gurgling sound
the gurgling noise is the water going into the base. since you haven't used it in so long your going to hear some weird noises at first then they should go away. but before using it make sure that all dust particals and everything is cleaned. if you have any more problems please let us know.
Jan 27, 2009 | Bionaire W9U Humidifier
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Vicks V3100 1.2 Gallon Humidifier Logo
1,222 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
