Sumsung wd-j1255c error message fe what does this mean please
  • aurevior Nov 30, 2008
    Of course there's nothing in the manual that mentions this error. Any ideas?
  • amo0one Dec 31, 2008
    i have the same Problem
3 Suggested Answers
SOURCE: Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Posted on May 29, 2009
  • 6277 Answers
SOURCE: My favourite function on my
Methinks a manual could help you quickly!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 29, 2011
Error FE on a LG WD 1274FHB what does it mean?
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 15, 2015 | LG Washing Machines
My LG WD-85260NP model Front load washing machine is showing the error as 'FE', what does it mean and how to rectify it? I have lost the manual in our transportation and I have downloaded the...
LG's 'FE' stands for 'overFlow Error' which I strongly suspect means a service engineer's attention. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 15, 2011 | Washing Machines
Washer / dryer model wd-j1255c stops on spin and displays F E
FE in a washer usually pertains to a overfilling usually due to a water valve issue, That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Jul 18, 2011 | Samsung Washing Machines
My favourite function on my Sumsung WD-J1255C wont update, how can I correct this?
Good luck,
John C.
Mar 29, 2011 | Washing Machines
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Nov 01, 2008 | Washing Machines
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
208 people viewed this question
Top Washing Machines Experts
