My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
    Scholar:
  • 157 Answers
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
Posted on May 20, 2011
My desktop screen monitor is not showing up and i can't find my control panel,my laptop name and model is-ACER TRAVEL/MATE 381TCi..how can i update and go to the internet???...it says(you may be a...
i think the operating system has been updated by u(knowingly or unknowingly) and the operating system is not original(pirated/cracked).
Buy an original one or use an oem version if u have got with ur machine.
The best method will be to format and reinstall the operating system and not update it.
Visit below links for more info
http://guideandtips.blogspot.com/2008/05/you-may-be-victim-of-software.html
http://forums.techguy.org/windows-xp/465966-you-may-victim-software-counterfeiting.html
Thanks.
Vote if found useful.
Jun 07, 2011 | ASUS Computers & Internet
SOFTWARE COUNTERFEITING
Firstly just buy genuine software!!!! Secondly try clicking resolve later
Oct 08, 2009 | Microsoft Office 2003 Basic Edition...
I am a victim of software counterfeiting
The only way you will ever get to get rid of that annoying counterfeit message is to install a genuine windows software, i.e. you need to purchase a unique windows software/CD for that pc. If you purchase the windows software, then during installation, in which you much boot from CD/DVD drive, you must select repair. That way all your documents will be preserved intact for you. The counterfeit message really simply is saying to you that, “look, this copy of the windows is actually owned by someone else and has been registered as such on Microsoft server.” Microsoft requires that each PC have a unique CD/software.
Aug 16, 2009 | Microsoft Office 2003 Basic Edition...
How to resolve software counterfeiting ?
paolo....sep24 2009
since start aug 23 2009 wenever i switch on my pc the welcum screen appears and den on it a dialog box appears as ur copy of windows didnt pass genuine windows validation and u may b a victim os software counterfeiting and der r 2 options "resolve now" or "resolve later". so as i click on resolve now my screen bcums black(wallpaper) and at the right hand corner the dialog blog consists of ur windows did not pass genuine windows and that stuff but i dont wanna install new software just want to get rid of tht **** pls pls pls pls help its freaking me man???? waiting for reply pl pls help????
Jul 13, 2009 | Microsoft Office 2003 Basic Edition...
U may b a victim of software counterfeiting
picture select right click mouse set as back ground desktob
Jul 10, 2009 | Microsoft Office 2003 Basic Edition...
Victim of software counterfeiting.this copy of windows did not pa
Just close this, it is not a Windows program. I opened it and got a virus.
Apr 21, 2009 | Computers & Internet
Software counterfeiting,did not pass genuine windows validation
message appearing on the screen that you may be a victim of software counterfeiting.this copy of windows did not pass geneuine windows validation. hiiii this is msg displayed on my screen
software counterfeiting,did not pass genuine windows validation problem,
Jan 25, 2009 | Microsoft Windows XP Professional With...
This means the Windows Validation Tool has checked your installed copy of Windows and has found it to be a non-genuine copy. This means the product key is non valid.
Where did you get the PC? If a "friend" installed Windows for you then he is using illegal product keys.
If you are sure your Windows is genuine, you need to telephone Microsoft and fight it out with them.
Jan 02, 2009 | Microsoft Windows XP Professional for PC
Victim of counterfeit microsoft software
sir it is possible that you got a pirated or counterfeited copy, you should reformat your drive and buy a licensed windows program. and use that to install your programs to you computer. thank you and fix ya.
Dec 17, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
