Question about Xerox Phaser 8560MFP Laser Printer
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
    Problem Solver:
  • 5 Answers
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
Posted on Apr 29, 2014
  • 883 Answers
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
SOURCE: Printing Problem, Xerox Phaser 6200
XEROX 6200 DP Printer doesn't print from DOS base program in windos XP. Printer is connected with parallel port
Posted on Apr 17, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560MFP/N System error
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Posted on Jul 31, 2009
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
My document is in portrait. I've used this same file for over 15 months. Now it is printing in landscape. I am loading the paper the same way I always have.
In your print driver, (start menu, printers and faxes, right click on your printer, select printing prefrences, and select protrait.)
This will set you back to your original portrait print prefrence.
Jan 07, 2011 | Xerox Phaser 7400/DXF Laser Printer
Hi can you tell me if the xerox phaser 8560mfp prints borderless please. Many thanks
No it doesn't. It is a shame because theoretically it is capable but it would require firmware/driver alteration which Xerox are unlikely to do.
Dec 20, 2010 | Xerox Phaser 8560MFP/N Printer
I have an hpdeskjet 960c. Will not print
follow the steps provided below..
  1. Open Ms word
  2. click on file
  3. click on page setup
  4. click on land scape and close the window..
Aug 22, 2009 | Office Equipment & Supplies
PDF files only print in landscape
Found it! The problem was that Adobe was set to print with page scaling set to Tile. Even though you see the preview as portrait (with page setup AND printer setup also in portrait), for Tile, it prints in landscape.
User said this fixed it.
Mar 25, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
I have xerox phaser 8560MFP error cod 07,010.43:14059
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
you could just rotate your photos.
or
the settings on the printer its self may need to be reconfigured.  1) go into your computer's control panel. 2) select "printers and faxes". 3) find your printer and left click it. 4) select "properties". 5) at the top of the menu that pops up choose "advanced". 6) once you click that look for a button near the bottom that says  "Printing defaults". 7) on the side you can choose for your printer to print in portrait or landscape.
Sep 08, 2008 | Adobe Acrobat 7.0 for PC
Paper trays
1. Remove the print driver on the PC if this is a local shared printer.
2. Re-share the printer will cause the driver to re-install.
Now the next way to fix issues like this too go to step 3, but only if step 1 and 2 does the same effect.
3. Turn it off and unplug it for 30 seconds.. Now plugin the power. Press and hold the power button for 30 seconds to force a reset back to factory defaults.
Still it sounds like a configuration error or bad network driver if this printer is on the network.
Jul 23, 2008 | Xerox Phaser 7700DN Laser Printer
Printing landscape instead of portrait
this article may explain how to change it
http://hints.macworld.com/article.php?story=20070613051850612
Mar 05, 2017 | HP OfficeJet 7410 All-In-One InkJet...
May 30, 2007 | Printronix LaserLine L1524 Printer
Xerox Phaser 8560MFP Laser Printer Logo
212 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
