Question about Bose Acoustimass 10 III System
I have a Bose 321 series III bass unit. Would like to run a preamp out into it from my reciever. does any one have a pin out diagram for the 15 pin sub D connector on these. Thanks in advance
3 Suggested Answers
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
  • 10 Answers
SOURCE: Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Posted on Mar 22, 2010
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Bose 321 sound fading
Try the following:
1) Switch the unit off completely, using the powerswitch on the back of the bass box.
2) Switch the unit back on via de switch on the bass box.
3) The display should read BOSE 321 and than be dark.
4) Insert a CD and switch the unit on with the remote by selecting the CD/DVD mode.
5) When the sound is now OK, it means that you need to contact Bose to ask them for the latest software update for your unit. After updating your system. The problem will not reoccur.
6) in case the problem continues and at start-up using a CD, no improvement of sound is heard, the system should go into repair. Contact Bose in your country and ask for return instructions.
Jan 13, 2014 | Bose Audio Players & Recorders
Bose 321 series II giving very dull sound in all inputs. Occaisionally the sound cuts and comes back with full and bright trebble, but then cuts back to original dull sound. I cant see anything the ad
Try the following:
Jan 13, 2014 | Bose 321GS Series II System
I have a 321 serie II and doesn,t work
Check the mains power switch on the back of the bass unit. Is it in the "on" position?
Wiggle the plug of the mains lead, on the bass box side and make sure it is all the way put into the bass box.
Still no signs of life.? Look for a replacement mains cord or measure if indeed AC current is present on the plug.
Still no luck? Call Bose and have them check out your system.
Dec 01, 2013 | Bose 3·2·1 II System
Just purchased Sony DA5800 ES reciever will my Bose 901 speakers work with this? Need help
Bose 901 speakers are designed to use with the Bose equaliser patched between the pre-amplifier out and power-amplifier in of your receiver. Having said that, Bose did not invent EQ, neither is EQ a mystical process. Not sure which series 901s you are talking about, but I would definitely be experimenting with the built-in EQ supplied with your Sony DA5800 ES. The manual says you have +/- 10 dB of adjustment for treble and bass for each of the surround channels. That is not really adequate in my opinion, not only would I be seeking +/- 15 dB, but I would also like to be able to apply those adjustments at frequencies chosen by me, not just 'treble' and 'bass' To use the Bose EQ, it needs to be patched between a preamp output and power amp input. The Sony DA5800 ES has preamp outputs, so you could use these (Note that the built-in EQ is disabled when using these outputs) In this case you could either feed the signals back into the Sony (post Bose EQ) perhaps using a different 'Zone'. As an alternative option, you could power your 901's with a stand-alone two channel power amplifier. Then you get the full benefit of the Bose EQ as well as the surround sound from your Sony (front L+R speakers off) It all sounds like a lot of fun. Happy listening! Cheers, Don.
Nov 28, 2013 | Bose 901 VI Main / Stereo Speaker
Is it better too hook up a optical audio cable from a PS3 to a bose 321 series III or to hook up the optical audio cable from my TV audio out to the bose 321 system?
Hello, its always better to go the shortest route this would be ps3 right to the bose there are too many menu variables ,circuits, that would be involved if you involve the tv output as well. that theory applies to video as well always go directly from source to load without any additional switches (circuits) when possible.
Feb 22, 2011 | Bose GS Series 321GSIIIBK Theater System
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
Jun 24, 2009 | Bose Acoustimass 10 III System
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Bose Acoustimass 10 III System Logo
344 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
