Question about Samsung SGH-j200 Cellular Phone
My j200 centre joystick function hare wire and most of the time the left right up down doesnt work at all
    Sergeant:
  • 145 Answers
Sir you may change the connector immediately
Posted on May 20, 2011
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
How do I program hpm time switch hl03705 very hard
Hi Brian
First thing to note about this timer is that it has a button battery to hold your program & keep the LCD display alive. Use the release tab in the lower left corner to separate the timer from the relay mechanism. Not only does this allow access to the battery, but It is also easier to program this way without having to stand in front of your electric box with a torch, trying to program the unit. It can then be returned when set up to your requirements.
Programming is quite straight forward once you get used to it's idiosyncrasies.
It is all controlled by the tiny joy stick which also has a push button in the centre.
Start by pushing the centre button straight in, It will then show a list of functions. Use the up / down side of the joystick to choose the function you want.
If you just want to turn your device ON for example (with the front facia back in place in the switchboard) just click down past the bottom of the visible list till you see ON. Then press the centre button in. You will hear a click as the relay turns ON. Repeat the same for OFF or AUTO. The unit would normally be left in the AUTO mode to perform it's programmed timing routine.
There is also a RESET position which clears all data to allow you to start over, clean.
Use this same method to set the TIME & DATE. Use the joystick left & right or up & down to set the right time & date.
It has enough smarts to figure if it is day 1 or 7, seen in the LCD bars at the very top under plastic 1-7 numerals.
When your ready to set the timer up for the Turn On & Off times that you have chosen then press the CENTRE BUTTON IN and use the up & down joystick to select "PROG" for programming.
Note that on the lower grey plastic sides of the LCD display there is the letters stamped On on one side and Off on the other.
You use this as an indicator when setting up your ON & OFF times on the LCD display. The LCD display only puts a black marker on the actual LCD to indicate your chosen times.
You will use the up / down joystick to line up the time of day that you want and the Right joystick to mark all the spots between the hours you choose.
Very hard for me to get to specific here without running in and out to my timer, So.... remove your timer control facia and sit down somewhere comfortable & undisturbed and play around with these settings until you get them right. Then carefully plug the unit back in and .... voila... your in business.
Now.... back to finding a replacement for my timer which has bad contacts and sometimes won't turn the hot water ON when it should. 7 Years of On / Off for the hot water aint bad!
NOTE:
This is a seven day timer. At the very top of the LCD Display, from left to right you will see numbers engraved in the plastic. Once you programmed your date, there will be a tiny LCD mark under one of these numbers to indicate what day of the week it is 1-7.
When you have decided what hours you want the timer to turn ON & OFF, you will notice a tiny mark under position 1. You have actually only programmed position 1.
To program the other days of the week this timer has no shortcuts. You must continue the time programming (using joy stick) past 24 hours (Into the next Day) for it to move to the next days settings. Continue further for the remaining days of week. You will notice a notch under the etched plastic numbers. This indicates wether your programming a turn ON time for Monday thru Sunday.
It's definitely a pain to set up if you aren't aware of how it's done. Cant find a manual on line as a PDF file.
I will look through my paperwork and see if I still have the programming chart!
Good Luck with Yours
Found Supplier Here:
http://www.electricaldistributors.com.au/contact-us/naval-base-branch/
FOUND THE USER GUIDE INCLUDED WITH THE TIMER
SEE THE ATTACHED PDF FILE:.........
"HPM TIMER HL03705"
Uploaded to FixYa Manuals & User Guides
Feb 04, 2015 | Hardware & Accessories
How do you set the correct time ???
Press and hold the source button until the unit turns off. Then with the power off, press and hold the multi-function control (i always call this a joystick since you can move it left, right, up or down OR press it like a button and it reminds me of old video game controllers). When you press the joystick for a moment it will bring up an initial settings menu. Scroll to the clock option and press the joystick button to enter. Use left and right to select minutes and hours and use up and down to change to the correct time and you're done. Press source again to turn the unit back on and you should be good to go. Enjoy!
Dec 01, 2010 | Pioneer DEH-P5900IB CD Player
Etrex legend joystick problems
could be the hardware switch itself
Oct 05, 2017 | Garmin eTrex Legend GPS Receiver
Dualshock 2 up, down l1, l2 buttons problems
try to open it and press the key that are not functioning,, if it doesnt work maybe its the time for you to buy a ribbon for your joystick,,, you can use your old joystick that are not functioning and substitute them to the one you are using,,,, if you dont have that try asking your friend if they had a ruined controller... mind you that this only works for the original controller not for generic.... generic controller are disposable... once one key is not functioning you cannot expect to work that key again,,,
Oct 19, 2009 | Sony PS2 Dual Shock 2 Controller...
Left side and upe side joystick not working
yeah it happen with sony ericsson phone joystick problem.u have joystick problem u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.thanks
Apr 27, 2009 | Sony Ericsson K510i Cellular Phone
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
3230 joystick problem
trow ur cellphone in d river! den cry! dats d best solution!
Dec 14, 2006 | Nokia 3230
Samsung SGH-j200 Cellular Phone Logo
130 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
