Question about LG 22" FLATRON LCD Monitor
My monitor is 'processing self image setting' every 20 secs which is blocking me from my work etc. This 'blackout' lasts for about 7 secs and I am all out of solutions... I have been writing this for like 4-5 mins omg. Please help
2 Suggested Answers
  • 3 Answers
SOURCE: Hi, My Lg Dlp turns
Hi im having the same problems to ,. im just going to replace the lamp ,. Ant that bad took it out to have a look and its easy
Posted on Nov 25, 2010
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
Iput in new lamp 25 days ago as working good. now when i t/on tv. It comes on for about 20 sec @ then t/off for aout 20 sec. By it self. and keeps repeating on/off/on/off/on/off picture @ sound ok.
The lamp of course would be logical to suspect---the only suggestion I have as have seen this before is some of these sets if enough dust inside will do this---seen ones that would play twenty minutes and either shut off or off and on.
Seen dead ones also where dust on the fans slows them just a little-set monitors things like that===usually we take back off and set outside with a air compressor and clean all air channels out (air gets taken in from front area and exits rear).
It at worst will rule this possible solution out and at best may resolve the issue. Seen say fifty or more sets where after cleaning with air (no matter how clean the house is it may look like a dust storm when you air it out) the issue was gone.
One even had golf ball sized white spots in picture--dust inside the two month old set's light engine.
Good luck and I hope it helps as it cannot hurt.
Jun 13, 2012 | Hitachi Televison & Video
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Forgot my password I cant watch any channels
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull. Please rates me . Goodluck...................
Feb 03, 2011 | Panasonic TCL42U25 42 in HD-Ready LCD TV
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
Need to reset netgear router wpn824v2
Don't tell me you tried to upload the firmware from a wireless connection.
It's probably bricked. You could act stupid and send it back to Netgear, claiming it just died...(it did right?) and in the meanwhile, Staples is selling 624's for $40 this week.
Carl
Jul 05, 2009 | NetGear RangeMax WPN824 Wireless Router
Color pallete problems - buttons invisible, text blocks blackout
the prob is may be due to your slow connection of internet..... if connection is fast then change the internet setting into default setting..... the prob will resolved...if still hav a prob then asked me?
Mar 31, 2009 | Microsoft Internet Explorer 7
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
How many images can the DiMAGE A2 capture using a 256MB memory card ?
In general, storage capacity depends on which image size and quality you have selected. For your information, here is the number of images recordable in a 256MB Compact Flash in the respective image size and quality. Since the image size may vary depending on scenes and subjects, these are approximate values only. Image size 3264x2448 / 3264x2176 / 2560x1920 / 2080x1560 /1600x1200 / 640x480 Std: 106 / 118 / 167 / 243 / 381 / 1043 FINE: 61 / 69 / 99 / 146 / 235 / 781 X.FIN: 31 / 35 / 50 / 75 / 124 / 594 TIFF: 10 / 11 / 17 / 25 / 43 / 245 RAW and JPEG: 15 / 16 / 17 / 18 / 19 / 20 RAW: 21 Movie : Image size 544x408 / 320x240 Movie(15fps) : 7 min. 9 sec / 13 min. 44 sec Movie(30fps) : 4 min. 15 sec / 7 min. 3 sec
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
LG 22" FLATRON LCD Monitor Logo
1,022 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
