Question about Microsoft LifeCam VX-3000 Web Camera
Freezing up!!!!!!!!!!! Help me!!
Every since I installed a router, my wecam DOESN'T work, it just freezes up all the time!!!!!!!!!!!!!! What do I do to fix this problem??????
    President:
  • 8,637 Answers
Normal 0 How much memory do you have installed in your computer? It may need to be increased as this is likely to be the cause of your computer freezing.
Hope this is of some help. Bud
Posted on Jan 13, 2009
SOURCE:
Wireless freezing problem
There are many documented cases of this router being ****. How old is it? If you can return it do that. If not, get yourself a linksys. I know they are bit more expensive, but you get what you pay for.
Nov 07, 2013 | AGPtek TPLink TLWR740N IEEE 80211bgn...
Ps3 60gb freezing
Try this use your vacuum to suck out any dust that is in machine from front and back. Use compressed air (duster used on electronics) and spray the cd area and back area again, vacuum out. If this doesn\'t help then Call Sony PlayStation for replacement of machine.
Jun 25, 2013 | Atari Tales of Graces f - PlayStation 3
Freezing
A computer/notebook/laptop can freeze due to a lot of reasons. Here are few noteworthy ones. Check them and see if they help, if not then post a little detail of when it freezes more etc:
a) Antivirus programs have a great tendency of eating up memory quite quickly. So, get a lightweight antivirus program like Microsoft Security Essentials or Avast etc.
b) If you have a low RAM then it is recommended that you run very few applications at the background. Avoid running any unnecessary applications.
c) If you have a desktop set with lots of transitions and effects it can cause huge RAM and often results in freezing of system.
d) Your O/S could be a problem too. If the above things doesn't help try resetting/re-installing the O/S and hopefully it shall help you a lot.
e) Check your system for any viral activities. You can perform an online scan using many free online scanners like Trend Micro etc.
Oct 24, 2012 | Acer Aspire 3620 Laptop/notebook
Inside of icemaker freezing up where ice drops threw door have cleaned it out a few times but it starts freezing again soon.
I am convinced there is supposed to be a seal of some type on the little plastic doot that closes up over teh openindg. MY ice maker has never worked right, it freezes up, the dispenser doesn't work and it leaks.
I'm on a mission to figure this out today.
May 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My palm treo pro keeps freezing lately, when i would start writing a text and press the space bar in the 3rd time i would punch it, it will completely go to the menu screen and i canoot hear music or go to...
Most likely, a program that you have installed is causing your Palm to freeze up. If you remember installing a program when the freezing started, delete the program and check if it keeps freezing.
Jan 21, 2011 | Palm Treo Pro Smartphone
Comtrend Are Junk?
What do you mean your computer is freezing? If it's the operating system that is freezing then it's highly doubtful that it's the new router which is at fault. If the computer is slow and unresponsive then clear your internet cache, perform a defrag and also check the drive for any errors.
To clear the internet cache right click on internet explorer and select properties from the list. In the general tab where it says browsing history click on delete and follow the on-screen messages.
To perform a defrag click on the start menu then all programs, accessories, system tools and the disk defragmenter.
To check the disk for any errors click on computer, right click on local disk c and select properties, select the tools tab and check the volume for errors. Make sure you check both boxes to fix any errors found and then be patient as it cane take some time to complete.
If the problem is the internet which is freezing then perform a speed test on your internet connection and compare the speed to what your supposed to be getting. You can perform a speed test here >>>>>>
http://www.speedtest.net
If the speed isn't what it's supposed to be then of course get your own router.
I do recommend Netgear myself as i will only have them routers for my own personal use.
Regards.
Sep 29, 2009 | Computers & Internet
My Dell Dimension 2400 running home XP is freezing up. I have a good virus program that is updated and run everyday. It freezes up on line and then closes the site but recovers it following another freeze....
Typically, freezing is caused by Spyware, Malware or memory.
First, install and run Spybot and Malwarebytes. If still a problem, power off your system and remove all the memory modules. Install one at-a-time and boot your system to see which module is problematic. Hope this helps.
Jul 20, 2009 | Dell Computers & Internet
Internet Connection
ensure you have the latest firmware for your product installed, go to this link for latest firmware and the installation instructions
Sep 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
P-334WT Router Freezing
Your first step is to upgrade the firmware. OR re-install the firmware. Do you mean freezing like, lights lock up and stay on regardless of the activity? Which that would point to firmware. Or do you mean that your internet just cuts out? Which I would look more towards your computers browser, possible background applications or even the NIC.
Jun 14, 2007 | Zyxel P-334WT (P334WT) Firewall
Microsoft LifeCam VX-3000 Web Camera Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
